Ethernet Products
5667 Discussions
Intel Ethernet Connection I219-LM not working with Windows 10 deployment via WDS server
JJohn66
Hello, we have a Dell Latitude E7270 that has the Intel L219-LM Ethernet adapter. I am using a WDS server to deploy a Windows 10 Image onto the computer, but it does not get an IP address. I am able to deploy Windows 7 just fine, but not Windows 10. I loaded the Ethernet Driver version 20.7.1 to the boot.wim but when I boot up over PXE boot to deploy the image, it doesn't get an IP address. If you need clarification, more details or questions, please let me know. Thanks
SYeo3
Valued Contributor I
Hi JustinJ.,
Thank you for contacting Intel.
What was the operating system that you used for the deployment? Can you use other Windows* OS?
Sincerely,
Sandy
SScia
hi i have the same problem
Hi SalvatoreS,
With regards to the problem you've encountered, please provide more information:
1. Network Adapter Model:
2. Driver Version:
3. Make/Model of your computer:
4. Operating System:
5. Details of your configuration/Error Messages
We look forward to your reply.
Sincerely,
Sandy
