Ethernet Products
5657 Discussions
Intel Ethernet I219-V disconnecting on speedtest and restarting randomly
FPala1
My motherboard is Asrock B150A-X1 and it uses this ethernet controller
Just like the title,when i go over to speedtest.net and click begin test,speed will instantly go to 90ish mbps and then the adapter disconnects
Also at random times the adapter just restarts,are there any advanced settings that need to be changed in device manager?
I am using Windows 10 Pro 64-bit
Hi cvancek,
Thank you for contacting Intel.
Please try to run a ping test, try to ping your router's IP Address and see if you get Request Time Out.
Command line: ping -t
We'll wait for your test results.
Sincerely,
Sandy
FPala1
heres a screenshot : https://gyazo.com/aa52bdee4bda29fb598b95c582b9d1f2 Gyazo - aa52bdee4bda29fb598b95c582b9d1f2.png
I think it might be the ethernet cable,the clips that click in place are broken on both ends and i am gonna replace the cable when i get home in a couple hours
Hi cvancek,
Thanks for sharing your test results.
I see, it must be the cable since the ping results is not getting any time outs. Hope this help fix your random disconnection issue.
Have a great day.
Sincerely,
Sandy
