Ethernet Products
5667 Discussions
Intel® Ethernet Controller I350-AM4 MDI Test 4 Transmission Distortion Failure
Anthony_Keysight
Trying to pass MDI compliance and the only portion that is failing is the MDI compliance transmission distortion (test 4) by small margin. We have the same setup as previous projects, but the margin is barley failing. Margin is 10mV but we are around 10.18mV so its .18mV over with 2850mil trace length at the longest point. They go to Mag-jack devices so this shouldn't be an issue. These are straight fed from the i350 to the mag-jack devices.
Fikri_Intel
Hi Anthony_Keysight,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue. Please find below the link to the Intel® I350 datasheet and board design resources, which may assist with your current request. You may refer to the documentation for technical details and design references.
Intel® I350 Datasheet:
https://cdrdv2-public.intel.com/333171/ethernet-controller-i350-datasheet.pdf
Intel I350 Design:
https://www.intel.com/content/www/us/en/content-details/323852/intel-ethernet-controller-i350-reference-design.html?DocID=323852
For further technical assistance, especially regarding integration or custom design implementation, we kindly recommend reaching out to our Embedded Support Team, who are better equipped to provide in-depth guidance.
Embedded link: https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
Fikri O.
