Ethernet Products
5163 Discussions
Intel(R) Ethernet 10G 2P X520 Adapter twinax or fibre sfp
cpaol
Hello All
Please help
A customer has several servers with Intel(R) Ethernet 10G 2P X520 Adapter NICs.
They want to connect to Cisco Meraki 425 10gb switches. The documentation is not clear, can we use twinax cables to connect between the meraki switch and the Intel x520 NICs instead of buying lots of separate 10gb sfp and cables?
Hi Craigpaolozzi,
Thank you for posting in Wired Ethernet Communities.
We have Intel(R) Ethernet SFP+ Twinaxial cable for Intel X520 NIC, you can find more details regarding the cable specs from the link below.
http://www.intel.com/content/dam/www/public/us/en/documents/product-briefs/ethernet-sfp-twinaxial-cables-brief.pdf
I'd also suggest contacting Cisco for requirements with your desired setup to ensure compatibility.
Hope this helps.
regards
Vince
Hi Craigpaolozzi,
We'd like to check if you have additional query regarding Intel X520 NIC.
regards,
Vince
