Ethernet Products
5744 Discussions
Intel X550-at2 PCI-E card Update NVM one port dosen't work
Sam_lai
Hi
I bought a X550-at2 card (STLab N-440) . I tried to update its NVM .After the update was successful, I found that one of the network ports dosen't work. How can I fix this problem.
I updated the NVM of the network card because it couldn't operate properly at 2.5Gbp.
Use "X550_NVMUpdatePackage_v3_60"
Sazirah
Hi Sam_lai,
Regarding the issue reported, would like to reconfirm if you bought this Intel® Ethernet Connection X557-AT from STLab-N440? Also, could you share where you find the NVM update from?
Regarding this, I need your assistance to provide the ssu logs for us to analyze the issue. You may follow steps in the link below:
Sazzy_Intel
Sazirah
Hi Sam_lai,
Good day,
This is related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
Sazirah
Hi Sam_lai,
Good day.
This is regarding your enquiry above.
Since we have not seen an update, we will be closing this forum case from our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
