Ethernet Products
5671 Discussions
Intel X552 ixgbe driver
lnt10
We are currently using Intel X552 Ethernet Adapter as below and are switching to new kernel 6.6.21 . Have downloaded the latest ixgbe driver 5.19.6 but in the release note it says this driver only support up to kernel version 6.4 . Is there a version of ixgbe driver that supports kernel 6.6.21 ? If not, when will it be available ?
Thank You.
+-[0000:00]-+-00.0 Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DMI2
| +-02.2-[04-06]--+-00.0 Intel Corporation Ethernet Connection X552/X557-AT 10GBASE-T
| | \                              -00.1 Intel Corporation Ethernet Connection X552/X557-AT 10GBASE-T
lnt10
I used ixgbe version 5.18.11 and was able to compile successfully with kernel 6.6.21
so I think we are good.  Thank you for your help.
[ 51.597588] ixgbe: loading out-of-tree module taints kernel.
[ 51.607354] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.18.11
[ 51.615340] Copyright (C) 1999 - 2023 Intel Corporation
[ 51.621237] ixgbe 0000:05:00.0: vgaarb: pci_notify
[ 51.626593] ixgbe 0000:05:00.0: runtime IRQ mapping not provided by arch
[ 52.276454] esdp = 0x103
[ 52.288978] ixgbe 0000:05:00.0: HW Init failed with error code: -17
[ 52.300606] ixgbe: probe of 0000:05:00.0 failed with error -17
[ 52.307128] ixgbe 0000:05:00.0: vgaarb: pci_notify
[ 52.312486] ixgbe 0000:05:00.1: vgaarb: pci_notify
[ 52.317829] ixgbe 0000:05:00.1: runtime IRQ mapping not provided by arch
[ 52.325458] DEBUG: vendor_id = 0x8086, device_id = 0x15ad, mac_type = 0x5
[ 52.954704] esdp = 0x303
[ 53.133253] esdp = 0x303
[ 53.141522] HW reset completed with status 0
[ 53.275584] ixgbe 0000:05:00.1: Multiqueue Enabled: Rx Queue count = 12, Tx Queue count = 12 XDP Queue count = 0
[ 53.353496] ixgbe 0000:05:00.1: save config 0x00: 0x15ad8086
Azeem_Intel
Hello Int10,,
Hope you are doing well!
Thank you for your response. We would like to inform you that version 5.19.9 for Intel is the latest one. As of now, we don't have much information about any upcoming new versions. If Intel release a new version, you can find the information in the link provided below.
https://www.intel.com/content/www/us/en/download/14302/intel-network-adapter-driver-for-pcie-intel-10-gigabit-ethernet-network-connections-under-linux.html
Please do not hesitate in contact us, we are more than glad to assist you.
Azeem_Intel
lnt10
I tried to use the latest ixgbe version 5.19.9 and seeing some compile errors. Will need to fix these errors to continue with the testing.
Linh
Azeem_Intel
Hello Int10,,
This is the first follow-up regarding the issue (Intel X552 ixgbe driver) you reported to us.
We wanted to inquire whether you had the opportunity to review the plan of action (POA) we provided.
Azeem_Intel
lnt10
Azeem_Intel
Hello Int10,
Could you please share the error snapshot to validate and proceed further assistance.
Azeem_Intel
Azeem_Intel
Hello Int10,
Thank you for the update. We will proceed to close the case now. If you need any further assistance, please don't hesitate to let us know.
Azeem_Intel
