Ethernet Products
5736 Discussions
USB issues after installing E810-XXVDA4T Ethernet Network Adapter
jehake
I installed the E810-XXVDA4T adapter in a AMD Ryzen Threadripper machine running Ubuntu 22.04. Following the user guide, I have installed the drivers and NVM. After the installation, I am no longer able to access any USB ports.  Listing the USB ports gives:
$ lsusb
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Anyone else having experienced this?
Checking the driver and NVB versions gives:
$ ethtool -i enp74s0f1np1
driver: ice
version: 6.5.0-18-generic
firmware-version: 4.40 0x8001c96a 1.3534.0
expansion-rom-version:
bus-info: 0000:4a:00.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Irwan_Intel
Hello jehake,
Thank you for your posting in Intel Ethernet Communities.
Could we know if you already have the latest driver version 29.0 installed?
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Have you tried to turn off the system, boot into recovery mode and check if the USB working? Please share with us the kernel version as well.
Irwan_Intel
jehake
Hi Irwan,
Thanks for the reply.
The keyboard is connected via USB. When booting, I'm able to select recovery mode. But in the recovery menu, the keyboard no longer works. Also, when physically removing the E810 adapter from the PCI slot, the USB ports are working.
The kernel version is 6.5.0-18-generic.
I have the latest version of the driver installed. I followed the instructions in Sec. 3.1 of the E810-XXVDA4T User Guide, by installing the ice driver from source code and updating the NVM. Checking the driver and NVM version gives:
$ethtool -i enp74s0f0np0
driver: ice
version: 1.13.7
bus-info: 0000:4a:00.0
supports-test: yes
Jan Erik
Irwan_Intel
Hello jehake,
Thanks for the information. Could we also know if you have tried in different slot? It could be a resource issue with the MB.
Irwan_Intel
jehake
The motherboard has two available slots, one PCIEX8 and one PCIEX16 slot. I have tried both with the same result, but use the PCIEX16 slot as advised in the documentation.
Irwan_Intel
Hello jehake,
This could implies that it is some incompatibility or configuration issue with the MB.
Can I know if you have reached out to the MB manufacturer to see if they have any advice or configuration options that will solve the issue?
There may also be a BIOS update for the MB.
Irwan_Intel
jehake
Hello Irwan_Intel,
Thanks for your response. I have sent an email to to the MB manufacturer Gigabyte, and hopefully they will answer.
Jan Erik
Irwan_Intel
Hello jehake,
I'd like to follow up if there's any update from Gigabyte?
Irwan_Intel
jehake
Hi Irwan_Intel,
No response from Gigabyte yet...
Irwan_Intel
Hello jehake,
I'd like to follow up if there's any further questions from you or updates from Gigabyte?
Irwan_Intel
jehake
Hello Irwan_Intel,
I received a response from Gigabyte, asking if the latest BIOS version is installed, which it is. No further response this far, but at least someone reads the posts.
jehake
Devi_Intel
Hello Jehake,
Greetings,
I'm follow up behalf of Irwan_Intel. Appreciated you can advise already updated the latest drivers and BIOS as per Gigabyte requested. Please refer to the driver link as per suggested.
Besides there has any other information or solution give by gigabyte for this issue.
We will follow up after 3 business days in case we don't receive a response.
Thank You & Regards
Devi_Intel
jehake
Hello Devi_Intel,
The latest drivers and BIOS are installed.
I will forward any information and solution received from Gigabyte on this issue.
jehake
IntelSupport
Community Manager
Hello jehake,
Thank you for confirming that you have the latest drivers and BIOS installed. We will await your update if you receive any response from Gigabyte regarding this issue.
Thank you for using Intel products and services.
Sachin KS
Irwan_Intel
Hello Jehake,
I'd like to follow up with you regarding this case. Since the BIOS and drivers has been updated, is there any advise from OEM about the incompatibility or configuration issue with the MB?
Irwan_Intel
jehake
Hi Irwan_Intel,
I got a response from Gigabyte March 12: "We will check internally about your problem. Please await our reply here. Thank you."
REgards,
Jehake
vij1
Hello Jehake,
Greetings for the day!
Thank you for the response. We will wait for your update.
Vijay N.
Irwan_Intel
Hi Jehake,
I would like to follow up about the status of the case. Let us know if you have further questions.
Irwan_Intel​
jehake
Hi Irwan_Intel,
I'm still waiting for more information from Gigabyte.
Jehake
Sreelakshmi1
Hello Jehake,
Sree
Irwan_Intel
Hi Jehake,
As you're still awaiting a response from Gigabyte, we'll go ahead and close this thread. If you receive any updates or have additional concerns, please feel free to raise new questions in the forums.
This thread will no longer be monitored.
Irwan_Intel
