Ethernet Products
4898 Discussions
Intel XL710-QDA2 can no longer be changed to 2x40 or 1x40 mode with latest firmware 5.02
JPron2
The 40Gb modes can no longer be selected using the qcu64e utility since the firmware upgrade from 4.42 to 5.02. Only 4x10 and 2x2x10 options are offered but the XL710-QDA2 card is QSFP+ capable.
# qcu64e /NIC=1 /INFO
Intel(R) QSFP+ Configuration Utility
QCU version: v2.26.17.06
Copyright(C) 2015 by Intel Corporation.
Software released under Intel Proprietary License.
Adapter supports QSFP+ Configuration modification.
Current Configuration: 4x10
Supported Configurations:
4x10
2x2x10A (Top 2 lanes on Module0; Bottom 2 lanes on Module 1)
2x2x10B
Cards that already are in 40Gb mode continue to function in 40Gb mode, but they report invalid configuration with qcu64e:
# qcu64e -nic=1 -info
Current Configuration: Invalid
4x10
2x2x10B
We are using the i40e driver 1.4.25 on Redhat 6: 2.6.32-573.18.1.el6.x86_64 kernel
# ethtool -i eth4
driver: i40e
version: 1.4.25
firmware-version: 5.02 0x80002285 0.0.0
bus-info: 0000:06:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
It looks like there is currently no way to downgrade the firmware, which make the cards that are now stuck in 4x10 unusable for us.
st4
New Contributor III
Hi Joeri,
Yes, there is no way to downgrade the firware, but let me check on the configuration issue you encountered.
rgds,
wb
st4
New Contributor III
Hi Joeri,
Can you help check the following:
1) What is the exact QSFP+ configuration utility used?
Is it downloaded from
https://downloadcenter.intel.com/download/25851/Intel-QSFP-Configuration-Utility-Linux- https://downloadcenter.intel.com/download/25851/Intel-QSFP-Configuration-Utility-Linux-
dated 3/14/16
OR
https://downloadcenter.intel.com/download/25849/Intel-QSFP-Configuration-Utility-OS-Independent- https://downloadcenter.intel.com/download/25849/Intel-QSFP-Configuration-Utility-OS-Independent-
dated 2/18/16
2) You mentioned cards already in 40Gb mode despite the "invalid configuration" error reported in qcu64e, does it mean the XL710-QDA2 is running in 40GBps connection without problem?
3) Can you try using other QSFP+ utility (dated 2/18/16 or 3/14/16) and cehck if the same issue persist?
4) When you try to run the command below, what is the output?
qcu64e -nic=1 /set=2x40
5) How many ports were active on the affected XL710-QDA2( are you referring to one QDA port connects to 40Gb switch port?)
Feel free to update me.
wb
JPron2
1) the first link for Linux
2) Yes, luckily they are working without any problem in 40Gbps mode
3) Just tried it, same result
4) Here it is:
qcu64e /NIC=1 /SET=2x40
Current Configuration: 2x2x10A (Top 2 lanes on Module0; Bottom 2 lanes on Module 1)
4x10
2x2x10B
Error: The chosen configuration is not supported by this adapter.
5) We have 2 ports active in 40Gb mode
st4
New Contributor III
Hi Joeri,
Thank you for the info. Let me check on this.
rgds,
wb
st4
New Contributor III
Hi Joeri,
Can you also provide the serial number and marking on the affected XL710-QDA2 and installed module?
Here is the link where you can refer to locate the serial number:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007022.html Identify Your Intel® Network Adapter Model Using Serial Number
For the installed modules, please provide all the numbers written on the modules.
Thanks for your time on this.
rgds
wb
JPron2
it should be (please note that the link supplied is not for the XL710):
serial: 3875 3153 5870 6609 5387 8056
mac: 68:05:ca:34:8c:88
module: 1450 U90W1E1100 (*2)
SYeo3
Valued Contributor I
Hi Joeri,
Thanks for the updates. We'll check on this and update you with our findings.
Sincerely,
Sandy
st4
New Contributor III
Hi Joeri,
Than you for the info. Yes the link is not for the XL710 but the serial number should be something similar to that format but with additional digits. The serial number of XL710 should be in the format of 15 digits + 6 digits + 6-3
e.g
xxxxxxxxxxxxxxx xxxxxx xxxxxx-xxx
What is the brand of the modules?
thanks,
wb
JPron2
might this be the serial:
6805CA348C880080515ADH57401001
st4
New Contributor III
Hi Joeri,
Thanks this is the serial number.
rgds,
wb
st4
New Contributor III
Hi JOeri,
rgds,
wb
JPron2
Where do I find the brand of the module?
The text I have on QSFP+ is:
1450 U90W1E1100
FYI: we just received new XL710 cards and they do offer the 40Gb configuration options. mac starts with 3C:FD:FE: the older "broken" cards have mac starting with: 68:05:CA
st4
New Contributor III
Hi JOeri,
Thank you for the update, good to know the other NIC is working fine. I did not receive information that there is known issue
for the network adapter with mac address start with 68:05;CA. Please update me if you still have other concern about this.
wb
A_L_Intel
This behavior is due to errata # 48 reported in the http://www.intel.com/content/www/us/en/embedded/products/networking/xl710-10-40-controller-spec-update.html Intel® Ethernet Controller XL710: Specification Update. The actual QCU (not the adapter firmware) is noticing that your adapter is using B0 silicon which was affected by this errata, and deciding not to allow a configuration change back to 40 GbE mode.
This errata doesn't matter if you are operating in 10 GbE mode. If your adapter(s) need to operate in nx40 GbE mode, we'd rather you get warranty replacements than trying to downgrade the firmware to trick it into working... as you can see from the errata description it's not a trivial issue.
Apologies for the lack of documentation around this change in QCU behavior, it was an oversight on our part and we'll be fixing that shortly.
South
MAnza
Hi
Is there an update on this issue? I am also facing the same problem.
My OS is Ubuntu 14.04.4 LTS
The card I have is Intel XL710-QDA2. /message/380703# 380703
Output of qcu info
./qcu64e /nic=1 /info
QCU version: v2.27.10.01
Copyright(C) 2016 by Intel Corporation.
4x10
2x2x10B
My card have mac starting with: 68:05:CA.
:~$ ethtool -i p1p1
driver: i40e
version: 1.4.25
bus-info: 0000:81:00.0
supports-test: yes
Is there a way I can use this in nx40 GbE mode ? Is there a fix available. Please help.
Anzal
MAnza
Hi
I think there is no update on this. I am OK with procuring a new XL710 QDA2. But how can I assure that the new one wont have this issue ?
My current MAC starts with 68:05:CA. I read on the thread here that adapters with MAC starting with 3C:FD:FE: does not have the issue.
Please let me know how to procure a proper adapter. Some model number,date,- some info that can assure that it can work in 40 G mode.
Anzal
AAlex20
Got the same problem. As for me Intel should start recall affected hardware program.
Got 01/2016 production month replacement, is there any way to know hardware/silicon revision?
