Ethernet Products
5671 Discussions
Intel XXV710-DA2 DDP missing?
takigama_pjr
Hi All,
I have a generic XXV710-DA2 dual 25G card that I really bought to play around with dpdk. So far, that has been .. hard... to say the least. But i've hit a roadblock. There is supposed to be a DDP PPPoE for the x710 (as per here https://doc.dpdk.org/dts/test_plans/ddp_ppp_l2tp_test_plan.html), and that points at https://downloadcenter.intel.com/download/28040 to download the ddp for PPP for the card.
Having spent a couple of hours trying to find it, it just doesn't seem to exist? or has been removed from downloads?
Anyone know where its moved to or where I can download it from?
Regards, Paul
Poojitha
Hi takigama_pjr,
Thank you for your patience. We would like to inform you that DDP profiles of X710 are in the Ethernet driver pack under \Release_30.3\DDP_Profiles\710_Series
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
We look forward to hearing from you soon.
Poojitha N
Azhari_Intel
Hi takigama_pjr,
Thank you for contacting Intel.
We appreciate you reaching out to us regarding the reported issue.
For your inquiry regarding Intel® Ethernet Network Adapter XXV710-DA2, kindly refer to the following resources:
XXV710 Datasheet: https://www.intel.com/content/www/us/en/content-details/332464/intel-ethernet-controller-x710-xxv710-xl710-datasheet.html?wapkw=ddp%20x710&DocID=332464
Dynamic Device Personalization XXV710: https://www.intel.com/content/www/us/en/developer/articles/technical/dynamic-device-personalization-for-intel-ethernet-700-series.html
These documents should provide the necessary technical insights.
If further assistance is needed particularly for advanced configuration or integration support, we kindly recommend opening a case via the Intel Premier Support (IPS) portal.
https://www.intel.com/content/www/us/en/support/articles/000057045/ethernet-products.html
We appreciate your understanding on this.
Azhari_Intel
takigama_pjr
Thanks for the reply Azhari,
i've been to all those links, the problem I have is the DDP packages are all missing (or dead links), for eg if you go down the bottom of that DDP XXV710 link you've posted (not the datasheet) at the button is this:
But both those links are dead, and everything that's points to the DDP packages for the 710's seem to be dead as well (the ones for the 800's can be found though)?
I'll raise a case soon, but I was kind of hoping some knew if they have been moved. The download site doesn't seem to be able to find them via search with any particular set of search keywords that I can find.
Regards, Paul
Akshaya1
Hi takigama_pjr,
Thank you for your response.
Kindly allow sometime to review the details and will get back to you with an update shortly.
Akshaya
Intel Customer support Technician
Poojitha
Hi takigama_pjr,
Poojitha N
takigama_pjr
Thanks Poojitha!
Exactly what I was looking for!
Regards, Paul
Azhari_Intel
Hi takigama_pjr,
Good day to you.
We are glad to hear you are able to find the files you are looking for.
As of now, we are proceeding to close this case.
Should you require any further assistance, please feel free to reach out to us.
Azhari_Intel
