Ethernet Products
5779 Discussions
Intel i211-AT linux driver
AYang11
where could find intel i211-at ethernet linux driver ? (02:00.0 Class 0200: Device 8086:1532 (rev 03))
igb-5.3.5.3.tar.gz does not include support intel i211-at device
i need porting it to intel braswell android 5.1.1
Hi Aaron,
Good day. Have you tried the suggestion provided by Eugenio? I believed he sent an email to you.
wb
AYang11
he provides me with freebsd driver .It differs with pure linux os .
i could not use it on intel android x86
aaron
Hi Aaron,
Just to double check were the original igb-5.3.5.3.tar.gz you downloaded before from the website below?
https://downloadcenter.intel.com/download/13663/Intel-Network-Adapter-Driver-for-82575-6-82580-I350-and-I210-211-Based-Gigabit-Network-Connections-for-Linux-
Have you also tried the one from sourceforge?
https://sourceforge.net/projects/e1000/files/igb%20stable/
wb
Hi Aaron,
You can also try checking also with your board vendor for the latest Linux driver on your system as this is an onboard NIC, the board vendor might have the customized driver suits the system.
Hope this helps.
rgsd,
wb
AYang11
i try to update firmware and added mac address.
it can working on pure linux kernel 3.14 . ^_^
Hi Aaron,
I am glad you resolved the issue and thank you for sharing the information.
rgds,
wb
