Ethernet Products
5821 Discussions
Is there any performance issue when configuring VLAN on a VF?
CChar6
Hi experts,
I add a vlan via libvirt as below. i assume it is the same as "ip link set SOME-DEV vf 1 vlan 213"
NIC is 82599ES.
Charto
Hi Charto,
Thank you for the post. No issue mentioned in our guide http://www.intel.com/content/dam/doc/design-guide/82599-sr-iov-driver-companion-guide.pdf and you may refer to the README file for reference, so far there is no specific mention about there is performance issue. http://downloadmirror.intel.com/14687/eng/README.txt
Is there any specific issue you encountered?
rgds,
Wb
Hi Charto,
rgds,
Wb
CChar6
Thanks for your comment. Since enabling vlan filter requiring some additional hardware resource i guess, I just want to make sure of this.
HI Charto,
Thank you for the post. There is no specific mention about performance issue of VLAN in VF in our guide and README file below:
1) http://www.intel.com/content/dam/doc/design-guide/82599-sr-iov-driver-companion-guide.pdf
2) http://downloadmirror.intel.com/14687/eng/README.txt
Any issue you encountered with the setup?
rgds,
wb
