I am experiencing some issues when trying to set up the ACC100 LDPC card. While following the steps from pf-bb-config However, we experience the following issues:
Baseband devices using DPDK-compatible driver
0000:ca:00.0 'Device 0d5c' drv=vfio-pci unused=
0000:cb:00.0 'Device 0d5d' drv=vfio-pci unused=
0000:cb:00.1 'Device 0d5d' drv=vfio-pci unused=
zq40@tc319-srv2:/opt/dpdk-stable-21.11.2-older/app/test-bbdev$ dmesg | grep "DMAR: IOMMU"
[ 0.457583] DMAR: IOMMU enabled
[ 0.457977] DMAR: IOMMU enabled
zq40@tc319-srv2:/opt/dpdk-stable-21.11.2/app/test-bbdev/test_vectors$ sudo dpdk-test-bbdev -c F0 -a cb:00.0 --vfio-vf-token=00112233-4455-6677-8899-aabbccddeeff -- -c validation -v ldpc_dec_v2342_drop.data
[sudo] password for zq40:
EAL: Detected 56 lcore(s)
EAL: Detected 2 NUMA nodes
Option -w, --pci-whitelist is deprecated, use -a, --allow option instead
EAL: Detected static linkage of DPDK
EAL: Multi-process socket /var/run/dpdk/rte/mp_socket
EAL: Selected IOVA mode 'VA'
EAL: Probing VFIO support...
EAL: VFIO support initialized
EAL: using IOMMU type 1 (Type 1)
EAL: Probe PCI driver: intel_acc100_vf (8086:d5d) device: 0000:cb:00.0 (socket 1)
WARNING: Num of operations was not provided or was set 0. Set to default (64)
WARNING: Burst size was not provided or was set 0. Set to default (32)
WARNING: Num of lcores was not provided or was set 0. Set to value from RTE config (4)
Starting Test Suite : BBdev Validation Tests
Test vector file = ldpc_dec_v2342_drop.data
Device 0 supports 0 < N <= 0 queues, not 0
rte_bbdev_setup_queues(0, 0, 1) ret -22
Adding active bbdev cb:00.0 skipped
No suitable devices found!
+ Test suite setup BBdev Validation Tests skipped!
sudo dpdk-devbind.py -b igb_uio ca:00.0
zq40@tc319-srv2:/opt/dpdk-stable-20.11.5/app/test-bbdev$ cat /sys/bus/pci/devices/0000\:ca\:00.0/sriov_totalvfs
16
echo 16 | sudo tee /sys/bus/pci/devices/0000\:ca\:00.0/max_vfs
echo 16 | sudo tee /sys/bus/pci/devices/0000\:ca\:00.0/sriov_numvfs
zq40@tc319-srv2:/opt/dpdk-stable-20.11.5/app/test-bbdev$ sudo dpdk-test-bbdev -c F0 -a cb:00.0 --vfio-vf-token=00112233-4455-6677-8899-aabbccddeeff -- -c validation -v ./ldpc_dec_default.data
EAL: Selected IOVA mode 'PA'
Test vector file = ./ldpc_dec_default.data
== test: validation
dev:cb:00.0, burst size: 32, num ops: 64, op type: RTE_BBDEV_OP_LDPC_DEC
The test program just hung there with no progress.
链接已复制
Greeting Tom,
Thank you for posting Ethernet Community. I'm here to follow up case as per subject. Appreciate you can follow below Support with
DPDK https://www.dpdk.org/ kindly refer or open an Intel Premier Support case at https://www.intel.com/content/www/us/en/secure/forms/intel-premier-support/enrollment.html (Required Login/Create new account)
If you wish to support thru community case you may refer to the link below as well
https://community.intel.com/t5/Embedded-Connectivity/bd-p/embedded-networking-connectivity
We will follow up after 3 business days in case we don't receive a response.
Thank you & Best Regards,
Devi_ Intel
Greetings Tom_Q
Regarding your case number 05928775, we are following up to find out if you were able to complete the actions we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply
Devi_Intel
Greetings Tom_Q,
Your issue #05928775 is now considered resolved, therefore we are proceeding to close this ticket.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Devi_Intel
