We are using the LXT972M part as Ethernet 100BaseT transceiver and we are observing the E and H filed pulses at the time of near field scanning near to series resistors on the TXD and RXD lines and we placed 50R series resistors on the data lines, So could you please let us know the source and sink current capabilities of the LXT972M TXD and RXD pins.
Hi Vinay9,
Greetings!
Thank you for posting in Intel Community. We acknowledge receipt of your concern and want to assure you that assisting you is our top priority. To effectively troubleshoot the issue you're facing, we require some additional information from your end.
1. System information where the transceiver is installed
2. Please confirm whether the transceiver is pre-installed or purchased separately
Dinesh
Hello Vinay9,
Greetings for the day!
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Dinesh
