While recognized in Windows 10, Windows Server 2019 is not recognizing
1) Intel(R) Dual Band Wireless-AC 8260
2) Intel(R) Ethernet Connection I218-V
3) Intel(R) I211 Gigabit Network Connection
on Gigabyte X99-Phoenix SLI-CF motherboard with i7-6950X processors
For 1), the error is "A service installation section in this INF is invalid"
For 2 & 3, "Cannot install drivers. No Intel(R) adapters are present in the computer"
For #1, I tried restoring the drivers from an identical machine with Windows 10. For #2 and #3, I tried running ProWinX64.exe version 24.3
I also tried
https://downloadcenter.intel.com/download/4237/Ethernet-Administrative-Tools-for-Intel-Network-Adapters?product=71305
https://downloadcenter.intel.com/download/28396/Intel-Network-Adapter-Driver-for-Windows-Server-2019-
Is there any solution to get network adapters working on this motherboard with intel adapters? All non-intel drivers are working...
Also if I were to buy a new network interface card with RJ45 ports, how can I be sure it will work with windows server 2019? From the intel documentation, I thought that these dual NICs I already had would have worked.
Hi TC2378954983427,
Thank you for posting in Intel® Ethernet Communities.
For 1, you may post the query in the Wireless Communities.
For 2, kindly share the following:
- Exact Windows version including build information
- Device ID with Subsystem vendor and ID. For example - "PCI\VEN_8086&DEV_15BC&SUBSYS_15BC1849&REV_10"
- BIOS version of your Gigabyte X99-Phoenix SLI-CF
For 3, This is not supported on Windows 2019.
In case you would purchase a 1 GbE network interface card with RJ45 port, I210-T1 or I350-T4 can be your options. These are supported on Windows 2019. Please visit this link and go to the "Windows* support for 1 GbE Intel® Ethernet Network Adapters" section for the details.
Vince T.
Intel Customer Support
A Contingent Worker At Intel
Hi Vince,
Thanks for the information.
For #2,
Windows Server 2019 Server Standard 10.0.17763 Build 17763
Device Hardware IDs are
PCI\VEN_8086&DEV_15A1&SUBSYS_E0001458&REV_05
PCI\VEN_8086&DEV_15A1&CC_020000
motherboard BIOS is F6d with release date 06/25/2018
TC
Hi TC,
Thank you for sharing the information.
Let me check this internally and get back to this thread as soon as possible.
Vince T.
Hi TC,
Good day!
After further confirmation, the I218-V is targeted for client systems and is not supported on Windows Server 2019.
Let us know if you have other assistance needed.
Vince T.
A workaround I found was to install drivers for Intel(R) Ethernet Connection (2) I218-LM and Intel(R) Ethernet I210-T1 GbE NIC.
Hi TC,
Thank you for sharing the update. Please let us know if there's other assistance needed.
Vince T.
Hi TC,
Good day!
Please be informed the workaround you've implemented is not a supported configuration and some features may not work.
Vince T.
Hi TC,
The I218-V and I211 are integrated components and might have priority over PCIe lanes compared to add-on card. We'd suggest to get in touch with Gigabyte Support for this matter.
Please let us know if there's other assistance needed from Intel® Ethernet Communities.
Vince T.
Hi TC,
Glad to be of assistance. Please let us know if you have other query related to Intel® Ethernet products.
Vince T.
Hi TC,
Good day!
It's been some time since we've heard from you. Hope we're able to answer your query related to Intel® Ethernet products. We'll now proceed to close the support case associated with this thread.
Feel free to create a new thread if you have other assistance needed from Intel® Ethernet Communities.
Vince T.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
