Hello
When will Intel finally fix the lack of Vlans under Windows 11 i219-LM
Hi Krzysztof6,
Greetings!
"When will Intel finally fix the lack of Vlans under Windows 11 i219-LM". Are your referring to Intel® Advanced Network Services Support on Windows 11? If No, Please help elaborate your concern. If yes, Please note that Microsoft has stopped the support on ANS for windows 11 and all windows Client OS editions. So it is the OS itself that is not supporting it and Intel Driver (Proset and ANS) wont make any difference if the OS does not supports the feature.
Please refer:-
https://www.intel.com/content/www/us/en/support/articles/000087483/ethernet-products.html
Please let us know if this information was able to answer your query, if you have any addnl. issue/Query, please let us know.
Subhashish_Intel.
Hi Krzysztof6,
Greetings!
Please refer:-
Subhashish_Intel.
Thank you for your answer, as usual Microsoft must screw something up
HI Krzysztof6,
Greetings from Intel.
Hope you are doing great.
Thank you for the response.
Kindly revert back to us and let us know if you need any further assistance or if we can go ahead and archive this case.
Thank you for using Intel products and services.
Ali
Hi Krzysztof6,
As there is no other issue/query from your end on this, we are proceeding to archive this ticket. Should you require any further assistance on any issue, please feel free to connect with us.
Thank you for choosing Intel.
Subhashish_Intel.
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
