Ethernet Products
5563 Discussions
Observing fluctuations during throughput test on 10G Fortville Nic
MSaiK2
Hi Support team,
While testing throughput test on 10G Fortville Nic(XL710) we are observing fluctuations in throughput. From below intel document I have understood that there will be a reasonable fluctuations during the test, so can you please confirm how much percentage of fluctuations can be expected.
https://www.intel.com/content/dam/www/public/us/en/documents/technology-briefs/sr-iov-nfv-tech-brief.pdf
M SaiKrishna
Mike_Intel
Hello MSaiK2,
Upon further checking, for information involving DPDK, you need to contact our DPDK support team. Please open the link below, click on "login and Access" to contact DPDK support.
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Let us know if you have any other questions.
Michael L.
Intel Customer Support
Under Contract to Intel Corporation
Mike_Intel
Hello MSaiK2,
Can you share us your output for us to check?
Let me also check if you are using on-board NIC?
If you have questions, please let us know.
Michael L.
MSaiK2
Hi Michael,
We cannot share the output due to NDA agreement.
Can you please let us know what is meant by on-board NIC?
M SaiKrishna
Mike_Intel
Hello MSaiK2,
It will be hard for us to determine if the fluctuations that you are getting is still within the range if there is no data for us to analyze. So the only details that we can still provide is the one from the link that you provided.
On-board NIC is a Network card embedded in the motherboard.
Michael L.
MSaiK2
Hi Michael,
We are observing throughput variance from 83% to 92%, when you tested have you seen such huge difference ?
and our's is not a on board NIC.
M SaiKrishna
Mike_Intel
Hello MSaiK2,
Can you provide the markings of your NIC card?
You can take a photo of the card on both sides form me to validate the markings.
Michael L.
MSaiK2
Hi Michael,
It's hard to get photograph of the NIC as our lab is in different location, if it's mandatory then we will try to get but it will take couple of days.Meanwhile if you need any CLI output we will try to provide from the node.
M SaiKrishna
Mike_Intel
Hello MSaiK2,
You may also try to generate SSU. Please download the System Support Utility from the link below, and attach a log file for us to investigate this issue.
1- Download from https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
2- Open SSU.exe
3- Mark the box "Everything" and then click "Scan".
4- When finished scanning, click "Next".
5- Click on "Save" and attach the file to a post.
Michael L.
MSaiK2
Hi Michael.
Our system will not support downloads from external sources, so we have requested for photographs of the NIC and it will take one or two days to get,
please find some testing details and information of the NIC,
NIC: Ethernet Controller X710 for 10GbE SFP+
Frame Size : 650
Packet sent: Forward-GTPU, Reverse Forward - IPv4
for above configuration we tested for 10 iterations and out of 10 iterations 5 iterations will be 84% line rate and other 5 iterations will be 92% line rate.
So when you tested for the same configurations how much tolerance you have seen and how much tolerance is acceptable?
M SaiKrishna
Caguicla_Intel
Hello M SaiKrishna,
Thank you fro the reply.
We understand that your system does not support external sources. While we are waiting for the photos of the NIC, can you share if you are referring to a single system? You've mentioned on your initial post that the NIC is 10G Fortville Nic(XL710). However, on the provided details above it is Ethernet Controller X710 for 10GbE SFP+. Please confirm if this is part of your testing, to use different systems and NIC to observe the fluctuations. If yes, please share the operating system used and model of the systems.
Crisselle C
MSaiK2
Hi Crisselle,
It's my mistake , Actuall NIC is 10G Fortville Nic(XL710)
M SaiKrishna
Mike_Intel
Hello MSaiK2,
For us to validate the card, we really need to get the markings of your NIC.
Michael L.
Mike_Intel
Hello MSaiK2,
Just want to make a follow up on the markings that we requested to validate the card.
Michael L.
MSaiK2
Hi Michael,
We are checking with concerned team but to get photographs they need to get some approvals and need to go through organization policies so this process might take a bit of time.
M SaiKrishna
Mike_Intel
Hello MSaiK2,
Can you tell us when can we expect the photos of the markings?
Michael L.
MSaiK2
Hi Micheal,
M SaiKrishna
Mike_Intel
Hello MSaiK2,
Thank you for sending the markings. Let me further check this and get back to you with the information that you requested.
Michael L.
Mike_Intel
Hello MSaiK2,
While we are checking this, let me also ask you if you are using DPDK driver?
Because according to the document, it is also based on DPDK driver.
Michael L.
MSaiK2
Hi Michael,
Yes, We are using DPDK driver.
Version :DPDK 17.11.0
M SaiKrishna
Mike_Intel
Hello MSaiK2,
Thank you for the update. Let me check on this and get back to you.
Michael L.
Mike_Intel
Hello MSaiK2,
Michael L.
