Ethernet Products
5535 Discussions
Omnipath client gets disconnect and reconnect again with other node
PASOK2
I see disconnect errors between server and client. Problem is isolated to one client. from Omni-Path OPA perspective what are logs that has to be checked which may have reported messages while the issue occurred.
Fabric controller: Intel Corporation Omni-Path HFI Silicon 100 Series
Hello pharthiphan,
Thank you for contacting Intel(R) Technical Support.
Be aware that this product is supported via out communities. For this you need to contact our https://www.intel.me/content/www/xr/en/support/contact-support.html?_ga=2.183586658.51291840.1523433383-1359619282.1512285886&erpm_id=5360843# @8 Intel® Fabric Products Support Option. I will go ahead to inform our Fabric Product support team so they can create a new case for you.
Jeremiah A.
Hello pharthiphan,
Jeremiah A.
