Quite a long time I am having a moderate number of packets being discarded while using my Windows 11 PC.
Sometimes online gaming experience is not quite good and specially while those discarded packets are occurring.
I've tried different driver versions from ASUS website (my motherboard is an ASUS Z690M PLUS D4 - Intel I219-V onboard NIC).
Could you please help me with that issue?
This is an output of the netstat -es command after using internet for 2 hours (browsing, watching videos etc):
Interface Statistics
Received Sent
Bytes | 2,988,250,052 | 246,451,560 |
Unicast Packets | 9,136,716 | 1,439,528 |
Non-unicast Packets | 36,260 | 176,936 |
Discarded | 136,376 | 0 |
Errors | 0 | 0 |
Unknown Protocols | 0 | 0 |
IPv4 Statistics
Received Packets | 59,602 |
Header Errors | 0 |
Address Errors | 0 |
Forwarded Datagrams | 0 |
Unknown Protocols Received | 0 |
Received Packets Discarded | 4,457 |
Received Packets Delivered | 83,782 |
Outgoing Requests | 66,190 |
Routing Discards | 0 |
Outgoing Packets Discarded | 5 |
Outgoing Packets without Route | 3 |
Reassembly Required | 0 |
Reassembly Successful | 0 |
Reassembly Failures | 0 |
Successfully Fragmented Packets | 0 |
Fragmentation Failures | 0 |
Fragments Created | 0 |
IPv6 Statistics
Received Packets | 1,031,519 |
Header Errors | 0 |
Received Packets Discarded | 42 |
Received Packets Delivered | 1,048,955 |
Outgoing Requests | 337,796 |
Outgoing Packets without Route | 0 |
ICMPv4 Statistics
Message Type Received Sent
Messages | 54 | 21 |
Errors | 0 | 0 |
Destination Unreachable | 54 | 21 |
Time Exceeded | 0 | 0 |
Parameter Problems | 0 | 0 |
Source Quenches | 0 | 0 |
Redirects | 0 | 0 |
Echo Replies | 0 | 0 |
Echoes | 0 | 0 |
Timestamps | 0 | 0 |
Timestamp Replies | 0 | 0 |
Address Masks | 0 | 0 |
Address Mask Replies | 0 | 0 |
Router Solicitations | 0 | 0 |
Router Advertisements | 0 | 0 |
ICMPv6 Statistics
Messages | 1,959 | 318 |
Errors | 0 | 0 |
Destination Unreachable | 2 | 29 |
Packet Too Big | 0 | 0 |
Echo Requests | 0 | 0 |
MLD Queries | 472 | 0 |
MLD Reports | 0 | 0 |
MLD Dones | 0 | 0 |
Router Solicitations | 0 | 3 |
Router Advertisements | 1,211 | 0 |
Neighbor Solicitations | 244 | 39 |
Neighbor Advertisements | 30 | 247 |
Redirects | 0 | 0 |
Router Renumberings | 0 | 0 |
TCP Statistics for IPv4
Active Opens | 923 |
Passive Opens | 6 |
Failed Connection Attempts | 43 |
Reset Connections | 87 |
Current Connections | 9 |
Segments Received | 49,097 |
Segments Sent | 40,056 |
Segments Retransmitted | 63 |
TCP Statistics for IPv6
Active Opens | 834 |
Passive Opens | 0 |
Failed Connection Attempts | 10 |
Reset Connections | 90 |
Current Connections | 10 |
Segments Received | 67,883 |
Segments Sent | 53,306 |
Segments Retransmitted | 169 |
UDP Statistics for IPv4
Datagrams Received | 31,715 |
No Ports | 407 |
Reception Errors | 0 |
Datagrams Sent | 25,709 |
UDP Statistics for IPv6
Datagrams Received | 2,032,107 |
No Ports | 41 |
Reception Errors | 2 |
Datagrams Sent | 282,209 |
Hi bbainfo,
Regarding your issue, may I know if you have try to update the latest driver for Intel Ethernet i219V adapter? If no, you may want to update the driver following link below:
>Recommend to udpate via device manager instead of exe.file.
>Open zip file you downloaded above, follow steps below:
File Release 28.2.1->PRO2500->Winx64->choose NDIS68 (for Win10,Win11 & WS22) or Win11 for NetAdapterCx driver (Windows 11)
Let me know the outcome and we will assist you further.
Sazzy_Intel
Today I am using the latest driver version available and to install it, I’ve followed the steps you provided. But the behavior still persists. It is very strange. I play online competitive games and using Wireshark I can see a lot of Malformed packets with TCP protocols.
Hi bbainfo,
Good day.
Thank you for your reply. As checking with our internal team, since you have completed driver pack update, the best effort that we can advise you is to refer you back to OEM Asus to assist you further. Asus will be able to assist you in this issue as they designed the firmware for the controller differently and may have suitable firmware or nvm update for your ethernet controller.
We apologies as we only able to help with best effort assistance for your issue and appreciate your cooperation and understanding on this.
Thank you
Sazzy_Intel
Hi bbainfo,
This related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
It is still showing a lot of Discarded incoming packets, but it seems to be related to my ISP, as my Lenovo laptop - which also uses an Intel network card but different model - is showing the same behavior. The strange thing is: using my laptop wifi adapter Intel AX201, there are no discarded packets after hours of testing and I am using the same network, but instead of wired, it is wireless. I’ve also tried another router and the result is the same. I don’t know what else I can do. My ISP already replaced the fiber optic modem. Maybe they have some hidden issue on their network infrastructure
Hi bbainfo,
Regarding the issue you mentioned, unfortunately we can't confirm if it is related to ISP issue or others, but it will be the best way for you to check directly with the ISP and you also can check with the OEM company Asus regarding this issue. Hopefully this issue will be resolve as soon as possible at your end so you can continue your daily routine as usual.
Sazzy_Intel
Hi bbainfo,
Good day,
I would like to follow up if you have any questions or clarifications regarding this case.
Feel free to contact us should you need any further assistance, and we will be more than glad to continue assisting you.
Sazzy_Intel
Hi @Sazirah.
I don't have any further questions. I am going to troubleshoot this with my ISP and ASUS.
Hi bbainfo,
Thank you for your reply. Since you will continue troubleshoot the issue with the ISP and OEM, we will proceed to close this case #06002519 at our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
Should I use the drivers provided by Asus for my motherboard or the Intel website drivers?
Not only for network but in general (chipset, ME, GNA, etc)
