Ethernet Products
5716 Discussions
Onboard I219-V Discarded packets
bbainfo
Quite a long time I am having a moderate number of packets being discarded while using my Windows 11 PC.
Sometimes online gaming experience is not quite good and specially while those discarded packets are occurring.
I've tried different driver versions from ASUS website (my motherboard is an ASUS Z690M PLUS D4 - Intel I219-V onboard NIC).
Could you please help me with that issue?
This is an output of the netstat -es command after using internet for 2 hours (browsing, watching videos etc):
Interface Statistics
  Received Sent
Bytes2,988,250,052246,451,560
Unicast Packets9,136,7161,439,528
Non-unicast Packets36,260176,936
Discarded136,3760
Errors00
Unknown Protocols00
IPv4 Statistics
Received Packets59,602
Header Errors0
Address Errors0
Forwarded Datagrams0
Unknown Protocols Received0
Received Packets Discarded4,457
Received Packets Delivered83,782
Outgoing Requests66,190
Routing Discards0
Outgoing Packets Discarded5
Outgoing Packets without Route3
Reassembly Required0
Reassembly Successful0
Reassembly Failures0
Successfully Fragmented Packets0
Fragmentation Failures0
Fragments Created0
IPv6 Statistics
Received Packets1,031,519
Header Errors0
Address Errors0
Received Packets Discarded42
Received Packets Delivered1,048,955
Outgoing Requests337,796
Routing Discards0
Outgoing Packets without Route0
Fragments Created0
ICMPv4 Statistics
Message Type Received Sent
Messages5421
Errors00
Destination Unreachable5421
Time Exceeded00
Parameter Problems00
Source Quenches00
Redirects00
Echo Replies00
Echoes00
Timestamps00
Timestamp Replies00
Address Masks00
Address Mask Replies00
Router Solicitations00
Router Advertisements00
ICMPv6 Statistics
Messages1,959318
Errors00
Destination Unreachable229
Packet Too Big00
Time Exceeded00
Echo Replies00
Echo Requests00
MLD Queries4720
MLD Reports00
MLD Dones00
Router Solicitations03
Router Advertisements1,2110
Neighbor Solicitations24439
Neighbor Advertisements30247
Redirects00
Router Renumberings00
TCP Statistics for IPv4
Active Opens923
Passive Opens6
Failed Connection Attempts43
Reset Connections87
Current Connections9
Segments Received49,097
Segments Sent40,056
Segments Retransmitted63
TCP Statistics for IPv6
Active Opens834
Passive Opens0
Failed Connection Attempts10
Reset Connections90
Current Connections10
Segments Received67,883
Segments Sent53,306
Segments Retransmitted169
UDP Statistics for IPv4
Datagrams Received31,715
No Ports407
Reception Errors0
Datagrams Sent25,709
UDP Statistics for IPv6
Datagrams Received2,032,107
No Ports41
Reception Errors2
Datagrams Sent
282,209
Sazirah
Hi bbainfo,
Regarding your issue, may I know if you have try to update the latest driver for Intel Ethernet i219V adapter? If no, you may want to update the driver following link below:
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
>Recommend to udpate via device manager instead of exe.file.
>Open zip file you downloaded above, follow steps below:
File Release 28.2.1->PRO2500->Winx64->choose NDIS68 (for Win10,Win11 & WS22) or Win11 for NetAdapterCx driver (Windows 11)
Let me know the outcome and we will assist you further.
Sazzy_Intel
bbainfo
Thank you for your reply.
Today I am using the latest driver version available and to install it, I’ve followed the steps you provided. But the behavior still persists. It is very strange. I play online competitive games and using Wireshark I can see a lot of Malformed packets with TCP protocols.
Sazirah
Hi bbainfo,
Good day.
Thank you for your reply. As checking with our internal team, since you have completed driver pack update, the best effort that we can advise you is to refer you back to OEM Asus to assist you further. Asus will be able to assist you in this issue as they designed the firmware for the controller differently and may have suitable firmware or nvm update for your ethernet controller.
We apologies as we only able to help with best effort assistance for your issue and appreciate your cooperation and understanding on this.
Thank you
Sazzy_Intel
Sazirah
Hi bbainfo,
This related to your enquiries above, I would like to check if the issue has resolved?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
bbainfo
Thanks for the previous answer and the advice.
It is still showing a lot of Discarded incoming packets, but it seems to be related to my ISP, as my Lenovo laptop - which also uses an Intel network card but different model - is showing the same behavior. The strange thing is: using my laptop wifi adapter Intel AX201, there are no discarded packets after hours of testing and I am using the same network, but instead of wired, it is wireless. I’ve also tried another router and the result is the same. I don’t know what else I can do. My ISP already replaced the fiber optic modem. Maybe they have some hidden issue on their network infrastructure
Sazirah
Hi bbainfo,
Regarding the issue you mentioned, unfortunately we can't confirm if it is related to ISP issue or others, but it will be the best way for you to check directly with the ISP and you also can check with the OEM company Asus regarding this issue. Hopefully this issue will be resolve as soon as possible at your end so you can continue your daily routine as usual.
Sazzy_Intel
Sazirah
Hi bbainfo,
Good day,
I would like to follow up if you have any questions or clarifications regarding this case.
Feel free to contact us should you need any further assistance, and we will be more than glad to continue assisting you.
Sazzy_Intel
bbainfo
Hi @Sazirah.
I don't have any further questions. I am going to troubleshoot this with my ISP and ASUS.
Sazirah
Hi bbainfo,
Thank you for your reply. Since you will continue troubleshoot the issue with the ISP and OEM, we will proceed to close this case #06002519 at our end. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
bbainfo
Quick question:
Should I use the drivers provided by Asus for my motherboard or the Intel website drivers?
Not only for network but in general (chipset, ME, GNA, etc)
