Ethernet Products
5686 Discussions
PCI\VEN_8086&DEV_1502&SUBSYS_00021179&REV_04 PCI\VEN_8086&DEV_1502&SUBSYS_00021179 PCI\VEN_8086&DEV_1502&CC_020000 PCI\VEN_8086&DEV_1502&CC_0200
NAnde1
Hello all,
I have a Toshiba Z930, which requires the following Intel LAN driver, The scenario is this, if i download these drivers and install them directly onto the laptop they work fine. However when i try to deploy Windows 7 Ent using MDT the image gets deployed however the drivers for the "LAN,card reader, intel management components USB3.0 and wireless" do not install and device manager is displaying exclamations.
Im surprised that the error message says that the connection cannot be made to the deployment share because the following networking device did not have a driver installed
PCI\VEN_8086&DEV_1502&SUBSYS_00021179&REV_04.
So the connection did connect to the deployment share because it loaded windows 7, and the lite touch was executed i have monitoring enabled which show the installation. I have been searching high and wide for an answer and it appears that I need the WINPE drivers ( driver pack)
I have checked the inf files and that have been added to the out of box driver folder on MDT and the Inf files do not have the same hardware ID.
using ms trace the error reports that no networking adapters found. The network drivers for you device are not present.
any help would be appreciated.
Here are the Hardware ID when i manually install the drivers
SYeo3
Valued Contributor I
Hi NAUK,
Thank you for contacting Intel.
The Dev_1502 is actually Intel(R) 82579LM Gigabit Network Connection, latest driver for this part is available for download from website below:
https://downloadcenter.intel.com/download/18713/Network-Adapter-Driver-for-Windows-7- Download Network Adapter Driver for Windows 7*
About Intel® Drivers
The driver or software for your Intel® component might have been changed or replaced by the computer manufacturer. We recommend you work with your computer manufacturer before installing our driver so you don't lose features or customizations.
Hope this is helpful.
Sincerely,
Sandy
NAnde1
Hi Sandy,
thanks, I ran some test and it was user error I always had the correct drivers it was my MDT settings configured incorrectly
apeter79
Hi sir can you provide the same for 64 bit version ,i see above is for 32 bit windows 7
can you help for 64 bit version
apeter79
my pc is Dell 790 series and ethernet controller was not installed is the error code 28
apeter79
Thank very much for providing 64 bit version i have successfully installed it
Thanks for your support Intel Family
