Ethernet Products
5530 Discussions
PCIe Based Ethernet Controller Supporting 4 x SFP+
Aditya_Singh
Hi Intel Team,
Below is our application block diagram-
The requirement is to provide 4x SFP+ ports but X710-TM4 only supports 2x SFI and 2x 10GBASE-T.
1. Is there any other device or X710 variant that can support 4x SFP+ directly
2. Can you pls suggest dual port Media convert , to convert copper to fiber 10G as per above block diagram
Aditya
JunAn_Intel
Hello Aditya,
Thank you for the update.
I am glad that your issue is already solved. If there is no other issue regarding this matter, I will be closing this issue/thread.
Let me know if you still need my help by replying to this thread. Have a good day and Thank you for reaching out to Intel Support.
JunAn_Intel
Intel Customer Support
JunAn_Intel
Hi Aditya,
  1. There is no 4x sfp+ port support in Intel® Ethernet Network Adapter X710 variant.
You might consider to get Intel® Ethernet Network Adapter E810-XXVDA4 for OCP 3.0.
You can refer by this link below:
https://www.intel.com/content/www/us/en/products/sku/184820/intel-ethernet-network-adapter-e810xxvda4-for-ocp-3-0/specifications.html
Intel® Ethernet Product Compatibility Tool for Ethernet
https://compatibleproducts.intel.com/ProductDetails?activeModule=Intel%C2%AE%20Ethernet
2 . Currently Intel doesn't have media converter product available. You may refer to OEM.
We will follow up after 3 business days in case we don't hear from you.
JunAn_Intel
Aditya_Singh
Hi JunAn,
Thanks for your quick response.
As per product brief of X710-DA4  it supports quad port SFP+.
Do you see any limitation in using X710-DA4 into our design for quad port SFP+ requirement.
Also, request you to share the datasheet and other reference documents related to X710-DA4.
Aditya
JunAn_Intel
Hi Aditya,
Sorry for wrong information provided.
Yes, Intel® Ethernet Controller X710-DA4 does supports quad port SFP+, 10GBASE-SR and -LR optical transceivers
10GbE SFP+ DAC.
We don't have specific datasheet for this model, we only have full datasheet for this X710 series.
You may refer this link below:
https://www.intel.com/content/www/us/en/content-details/332464/intel-ethernet-controller-x710-xxv710-xl710-datasheet.html?DocID=332464
JunAn_Intel
Aditya_Singh
Hi JunAn,
Thanks for the confirmation. Can you please share below documents for X710DA4OCPV3 if available-
  1. Reference design (.DSN and .BRD file is preferred)
  2. Design guide and any other documents
  3. OrCAD symbol
  4. Footprint for Allegro
Aditya
Aditya_Singh
Hi JunAn,
There is little bit confusion here. We require an Ethernet controller supporting quad SFP+ modules but X710-DA4 is an Ethernet adaptor which uses X710-BM2 Ethernet controller. X710-BM2 is a dual port Ethernet controller which supports 2x SFP+ modules.
After further browsing on Intel website we came across XL710 series which supports quad SFP+ modules.
We are planning to use FTXL710-BM1 into our design for quad SFP+ module support requirement. Please share below documents-
1) OrCAD symbol for FTXL710-BM1
2) Allegro Footprint for FTXL710-BM1
3) EOL for FTXL710-BM1
4) Refence design (.DSN and .BRD preffered) for FTXL710-BM1
Aditya
JunAn_Intel
Hi Aditya,
As for your request, this is out of our scope. We only can provide Datasheet in this community.
Datasheet for Intel® Ethernet Controller X710/XXV710/XL710:
https://www.intel.com/content/www/us/en/content-details/332464/intel-ethernet-controller-x710-xxv710-xl710-datasheet.html?wapkw=xl710%20datasheet
Because the documents that you request is under Intel® Confidential, you might need to create a case in Intel® Premier Support (IPS).
Refer Intel® Premier Support link below:
https://www.intel.com/content/www/us/en/design/support/ips/training/welcome.html
Otherwise, you have to create a post in embedded community if you don't have Intel® Premier Support (IPS) access.
https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
JunAn_Intel
Aditya_Singh
Hi JunAn,
Thanks for the information. Please share the EOL details for FTXL710-BM1
Aditya
JunAn_Intel
Hi Aditya,
Good day to you.
Currently we don't have the info for End Of Life(EOL) details, you have to wait for intel announcement.
But Intel did mentioned about Expected Discontinuance.
Expected Discontinuance is an estimate of when a product will begin the Product Discontinuance process.
You might refer to the link below
https://ark.intel.com/content/www/us/en/ark/products/93104/intel-ethernet-controller-xl710bm1.html
JunAn_Intel
JunAn_Intel
Hello Aditya,
I hope you're having a wonderful day. I am just sending a soft follow up to check if you still have questions or clarifications. We will wait for your reply.
JunAn_Intel
Aditya_Singh
Hi JunAn,
Thanks for all the information. I don't have more queries regarding XL710-BM1 to post at this forum.
Aditya
JunAn_Intel
Hello Aditya,
JunAn_Intel
Aditya_Singh
Hi JunAn,
While browsing through datasheet of XL710, I found that there is only one package given in section 13.7-
There are total 8 SerDes lanes are available in XL710 series divided into two groups Group A and Group B. Same can be cross verified from table 2-3 into the datasheet.
As per product brief of XL710-BM1, it can support 4 x10GbE SFI modules.
Below are our queries-
1) Which group (group A or group B) will be available into XL710-BM1 variant
2) Is there any difference between package of XL710-BM1 and  XL710-BM2 variant
3) Section 1.1 shows the block diagram for XL710 series-
There are two block diagrams showing below information
a) As per figure 1-5 XL710 series supports: 2x 40G or 4x 10G/1G
b) As per figure 1-7 XL710 series supports: 2x40G or 4x 10G/1G/100M
Which XL710 variant supports option "A" and option "B"
Aditya
Aditya_Singh
Hi JunAn,
Can you please share your response on above queries.
Aditya
