I'm tired of this incompetence. I'm tired of turning "Prioritization Engine" off, only to have it turned back on during an update. How do I know this? Netflix stops working, images in Discord load 10x slower, and the machine is made more unstable.
I get that you are incompetent at software programming, I get that you really don't know what you are doing, that's perfectly clear.
So, what I want to do is receive clear, simple instructions on how to remove this disasterpiece. I need to disinfect my machine of this incompetence.
I don't want to ever have the speed of my internet (which is quite fast) horribly hobbled by your incompetence.
I need a list of steps to disable this immediately.
Hello WhySoIncompetent,
I will raise the case with our engineers to double check if there's a way that we can totally disable the Killer Intelligence Centre or to confirm what could be the appropriate recommendation that we can provide you.
Thank you so much for your patience.
Carmona A.
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
