Ethernet Products
5719 Discussions
Problem in Nios console
sRama28
i have used simple socket server example design code and added QSPI IP on it.after adding the IP in qsys nios 2 console is not printing anything.help to resolve this /or i need to any other setting
AlfredoS_Intel
Hi sRama28,
Thank you for posting in our Intel® Ethernet Communities page.
To be able to assist you accurately, may we know the Intel® product that you are asking assistance with?
Looking forward to your reply. Should we not get your reply, we will check back with you after 3 business days.
Alfred S
Intel® Customer Support
AlfredoS_Intel
Hi sRama28,
We have not heard from you yet, and we are reaching out to check if you need more time.
Should we not get your response, we will check back with you again after 3 business days.
If there is still no response, we may be forced to close the thread.
Alfred S
Intel Customer Support
sRama28
i m using MAX10 FPGA and Ethernet simple socket server sample code from intel website.
i added QSPI in qsys and compiles NIOS 2 simple socket server code the console is not printing when i run the ELF file in NIOS.
AlfredoS_Intel
Hi sRama28,
Thank you for your response,
We will be transferring your thread to our NIOS console forum.
Alfred S
SyafieqS
Hi Sathish,
Can you elaborate more about the project and what are expecting the output to be displayed in Nios console? Also what I understand Max 10 is not listed in the link below where have RJ-45 Ethernet cable.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/design-examples/intellectual-property/embedded/nios-ii/exm-hello_world.html
sRama28
i am having working Simple socket server code with evaluation board.
normal sof and ELF file running correctly.but if i tried with QSPI the NIOS is not booting and the console not printing anything..
please say any idea to boot NIOS processor.
SyafieqS
Hi Sathish,
You can take look at below link for reference for  Nios II Configuration and Booting Solutions
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/nios2/edh_ed_handbook.pdf (p218)
