Further design support with the implementation of mulitple Intel i210 NICs on a system board.
The design has x3 i210 devices. One i210 is on the system CPU module (E3875 Intel Baytrail). The other x2 i210 devices are on the system carrier board.
I can only able operate x2 i210 device simultaneously(x1 on the CPU and x1 on the carrier board). When a 3rd i210 is enabled the device manager shows an exclamation mark.
I do not have a hardware issue as I have tested all the devices independently. Each device as its own PCI lane. I have tried different configuration modes for the i210's. ie. Configured all with 1533 device ID. Configured x2 as 157B device ID and 3rd as device ID 1533. Configured x2 as 1533 device and the other as 157B.
Do I need to change the device, sub device ID for one of the i210 on the carrier board? If so how do I change the device ID
Please let me know if further detail is required.
Hi Amtote,
Thank you for the post. I have branch out your inquiry and have received your email. I will further assist from here. Can you share what is the exact brand and model of the system board?
wb
The system board is a custom designed qseven carrier board.
The qseven carrier board supports ARM, Intel, AMD.
Qseven module used for i210 testing = 3rd Gen Intel ATOM (Baytrail) - Intel Atom E3827 Dual core 1,75GHz CPU with 4GB DDR3
Cheers
Al
Hi Amtote,
Good day. Further checking, please submit your design for review via this link:
https://edc.intel.com/Tools/Design-Review/Default.aspx?language=en
The support team can better assist you from there.
You may refer to the embedded communities for reference:
https://embedded.communities.intel.com/thread/12880
wb
Hi
Tried the Intel review path before, however format of my schematic design files were rejected and they would not accept pdf format.
Amtote
Hi Amtote,
I am sorry to hear that, you need to contact the design support and check with them how to submit the schematic design. You can submit your feedback via link below:
https://edc.intel.com/Tools/Design-Review/Feedback/
The design review service center is in better position to assist on this request.
wb
