Ethernet Products
5776 Discussions
Receive side scaling
MMani7
I have few clarifications on the Receive side scaling (RSS) setting in a Windows 7 OS. I want to disable the RSS because it gives some performance issues, so executed the command "netsh int tcp set global rss=disabled" and when I checked at the Network adapter properties, I still see the Recieve side scaling is enabled.
1. I would like to understand the difference between setting the RSS disabled using the command and disabling the same using the Network adapter properties. (How it works, which takes priority)
2. Is there any known issues if the RSS is disabled using the command line.
please share any info on this topic.
Appreciate your help!
Prabu
Hi Prabu,
Thank you for the post. It is recommended to disable in the network adapter properties. You may refer to below website for known issue :
http://www.intel.ph/content/www/ph/en/support/network-and-i-o/ethernet-products/000006703.html
I will further check with regards to the difference.
Rgds,
wb
Hi Prabu,
Good day. As an additional information, In order to make the RSS work, enable or disable the option in both via command and network adapter property. You may refer to the Microsoft* website for reference (please note this is third party website in which Intel has no control, for your reference only).
https://technet.microsoft.com/en-us/library/gg162712(v=ws.10).aspx
Hope the above information help.
rgds,
wb
MMani7
Thanks for the update, I would like to know the known issues when the RSS is disabled in the command prompt only.
Hi Prabu,
The known issues are listed on the website, for issue in command prompt, you can click on the
http://support.microsoft.com/kb/2846837 Incorrect RSS processor assignment on a Windows* 8 or Windows Server 2012-based computer that has multi-core processors* (which is found on the website below)
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000006703.html
wb
MMani7
Thanks for the link. Is there any link that is specific to Windows 7?
Hi Prabu,
Can you share what is your network adapter model ? The kind of system you have eg. board model.
What driver version used?
wb
MMani7
The Network adapter model is "Intel(R) 82576 Gigabit Dual Port Network Connection" and "Intel(R) Gigabit CT Desktop Adapter".
The board is the customized 3rd party.
The driver version used is v19.1
Hi Prabu,
Thank you for sharing the information.
Rgds,
wb
Hi Prabu, The netsh command would disable the RSS service within windows while turning it off in the adapter properties would disable the service in the driver.
Hope this helps.
regards,
Vince
MMani7
So, If I want to disable the RSS, then I should disable it in Windows and also in the Network adapter properties, am I correct?
Hi Prabu, you're correct. need to disable it in Windows and network adapter properties.
regards,
Vince
MMani7
Thanks for the update Vince.
