Ethernet Products
5821 Discussions
Regarding previous question about i210 blue screening Windows
jorgecarousel
Hey guys,
Just to follow up on this: Intel I210 Blue Screening Windows when speed test is run  this is still happening and this time it happened at 689 Mbps, so i tried to run speed test from a Linux stick and I got 925 Gbps without an issue, so is it the driver or is it Windows?
Caguicla_Intel
Hello jorgecarousel,
Thank you for the update and we are sorry to hear that the issue reoccurs.
Just to confirm, have you tried installing the driver from HP? If not yet, we highly recommend to try the drivers from HP. Even if you see the driver came from Intel, possible that it has customizations based on the features of your motherboard.
Feel free to let us know if you have questions or clarifications.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel Customer Support
jorgecarousel
OK, I'm trying that now, I hope this works.
jorgecarousel
That didn't work either, I think I'm just going to go with what works, Linux, so you can close this too.
Caguicla_Intel
Thank you for the update and we are sorry if the OEM driver did not help with the issue.
We will now close this request as per your advise. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
