Ethernet Products
5602 Discussions
Remotely Configure Cyclone III Development Kit
Board: Cyclone III Development Kit
Device: EP3C120F780C7
I am trying to access the above mentioned board through Ethernet RJ-45 jack located on the LCD Multimedia HSMC. The web server application in the development established a connection to the internet and acquires an IP address via DHCP. However, in my case, no IP address is assigned as mentioned following:
"Web Server Info" displayed on LCD are as following:
IP Address: 0:0:0:0
Netmask: 255:0:0:0
Gateway: 0:0:0:0
The reason is that internet server located in my office does not automatically assign IP address to the newly connected device via DHCP. Each system in my office is assigned a static IP address.
Is there any option available for assigning static IP to the Cyclone III Development Board?. Or, some other alternative solution to this problem?
