Ethernet Products
5821 Discussions
SRIOV + ubuntu bonding in KVM
psund2
00:04.0 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
00:05.0 Ethernet controller: Intel Corporation 82599 Ethernet Controller Virtual Function (rev 01)
I have a KVM with Intel SRIOV card. 5: enp4s0f0: mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether 00:0c:bd:05:d9:82 brd ff:ff:ff:ff:ff:ff vf 0 MAC 00:0c:bd:05:d9:11, spoof checking off, link-state auto vf 1 MAC 00:0c:bd:05:d9:ab, spoof checking off, link-state auto vf 2 MAC 00:0c:bd:05:d9:a2, spoof checking off, link-state auto vf 3 MAC 00:0c:bd:05:d9:ac, spoof checking off, link-state auto vf 4 MAC 00:0c:bd:05:d9:ad, spoof checking off, link-state auto vf 5 MAC 00:0c:bd:05:d9:ae, spoof checking off, link-state auto vf 6 MAC 00:0c:bd:05:d9:af, spoof checking off, link-state auto vf 7 MAC 00:0c:bd:05:d9:a1, spoof checking off, link-state auto 8: enp4s0f1: mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000 link/ether 00:0c:bd:05:d9:83 brd ff:ff:ff:ff:ff:ff vf 0 MAC 00:0c:bd:05:d9:12, spoof checking off, link-state auto vf 1 MAC 00:0c:bd:05:d9:bb, spoof checking off, link-state auto vf 2 MAC 00:0c:bd:05:d9:bc, spoof checking off, link-state auto vf 3 MAC 00:0c:bd:05:d9:bd, spoof checking off, link-state auto vf 4 MAC 00:0c:bd:05:d9:be, spoof checking off, link-state auto vf 5 MAC 00:0c:bd:05:d9:bf, spoof checking off, link-state auto vf 6 MAC 00:0c:bd:05:d9:b1, spoof checking off, link-state auto vf 7 MAC 00:0c:bd:05:d9:b2, spoof checking off, link-state auto
I have used vf0 from each card in a GUEST Ubuntu machine
Physical Function enp4s0f0 has the following virtual functions: PCI BDF Interface ======= ========= 0000:04:10.0 0000:04:10.2 0000:04:10.4 0000:04:10.6 0000:04:11.0 0000:04:11.2 0000:04:11.4 0000:04:11.6
Physical Function enp4s0f1 has the following virtual functions: PCI BDF Interface ======= ========= 0000:04:10.1 0000:04:10.3 0000:04:10.5 0000:04:10.7 0000:04:11.1 0000:04:11.3 0000:04:11.5
Snippet of dumpxml
My bonding configuration:
uto eth1 iface eth1 inet manual bond-master bond0
auto eth2 iface eth2 inet manual bond-master bond0
auto bond0 iface bond0 inet static address 192.168.23.101 netmask 255.255.255.0 bond-slaves none bond-mode 2 bond-miimon 100 bond-downdelay 0 bond-updelay 0
cat /proc/net/bonding/bond0 Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: load balancing (xor) Transmit Hash Policy: layer2 (0) MII Status: up MII Polling Interval (ms): 100 Up Delay (ms): 0 Down Delay (ms): 0
Slave Interface: eth1 MII Status: up Speed: 1000 Mbps Duplex: full Link Failure Count: 0 Permanent HW addr: 00:0c:bd:05:d9:11 Slave queue ID: 0
Slave Interface: eth2 MII Status: up Speed: 1000 Mbps Duplex: full Link Failure Count: 0 Permanent HW addr: 00:0c:bd:05:d9:12 Slave queue ID: 0
bond0 Link encap:Ethernet HWaddr 00:0c:bd:05:d9:11 inet addr:192.168.23.101 Bcast:192.168.23.255 Mask:255.255.255.0 inet6 addr: fe80::20c:bdff:fe05:d911/64 Scope:Link UP BROADCAST RUNNING MASTER MULTICAST MTU:1500 Metric:1 RX packets:122 errors:0 dropped:0 overruns:0 frame:0 TX packets:295 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:33881 (33.8 KB) TX bytes:34294 (34.2 KB)
eth1 Link encap:Ethernet HWaddr 00:0c:bd:05:d9:11 UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1 RX packets:122 errors:0 dropped:0 overruns:0 frame:0 TX packets:183 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:33881 (33.8 KB) TX bytes:28212 (28.2 KB)
eth2 Link encap:Ethernet HWaddr 00:0c:bd:05:d9:11 UP BROADCAST RUNNING SLAVE MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:112 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:6082 (6.0 KB)
Here bond0 MAC is same as eth1 MAC as eth1 came up first. Issues is when I receive packets in PF corresponding to eth2 , packets are recieved in GUEST(eth2) , eth2 RX is 0 ...
What could be the issue..sometimes eth2 comes up first after reboot and bond0 has eth2 MAC and at that point eth1 RX is zero..
Hello Premnathsundarababu,
Thank you for posting in Intel Wired Ethernet Communities.
  • Please identify the Ubuntu version of the host system.
  • What device are the ports connecting to?
  • If this is a switch does it support 802.3ad, and is trunking or etherchannel enabled on the ports?
  • Please remove one of the cables to test if fault tolerance is working.
  • If spanning tree protocol is enabled this may also cause issues.
If you have any questions please do not hesitate to ask.
Daniel D
psund2
Hi Daniel,
Thanks for your response :
I am using ubuntu "14.04"
Its a cisco switch
I am using static port-channel
interface GigabitEthernet1/0/1
switchport access vlan 1010
switchport mode access
channel-group 1 mode on
spanning-tree portfast
interface GigabitEthernet1/0/2
interface Port-channel1
and xor bonding(type 2) in ubuntu
No.Even if i shut the working port in switch..I dont see any packets in ubuntu interface.
I am sure STP is switch side is not an issue here.
Spanning tree enabled protocol ieee
Root ID Priority 33778
Address e804.6271.8180
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 33778 (priority 32768 sys-id-ext 1010)
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/9 Desg FWD 4 128.9 P2p
Gi1/0/10 Desg FWD 4 128.10 P2p
Po1 Desg FWD 3 128.488 P2p
Po46 Desg FWD 3 128.848 P2p
Thank you for the reply. Please provide an ethtool -i output for the host Ethernet interface. We will investigate the issue and update you as soon as possible. Please let us know if you have any questions.
Daniel D
Please indicate the vendor of this adapter or the board if the controller is integrated into a motherboard. ethtool -i output for the interface would also be helpful to see the driver and firmware being used. Please let us know if you have any questions.
Daniel D
psund2
ethtool -i enp4s0f0
driver: ixgbe
version: 4.2.1-k
firmware-version: 0x1bab0001
expansion-rom-version:
bus-info: 0000:04:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: no
ethtool -i enp4s0f1
driver: ixgbe
version: 4.2.1-k
bus-info: 0000:04:00.1
supports-test: yes
Thank you for the output. We will continue to investigate this issue, and update you as soon as possible. Please let us know if you have any questions.
Daniel D
Please confirm if you have tested the bond in balance-xor without SR-IOV and KVM. Does the bond work properly prior to implementing SR-IOV and KVM? If you have any questions please let us know.
Daniel D
Intel Customer Support
Please let us know if you still need assistance with this issue. We just want to know if the bond is working without SR-IOV and KVM. Let us know if you have any questions.
Daniel D
Daniel D
