Ethernet Products
5671 Discussions
Simple NIOS Max 10 ethernet
I'd like to implement a very simple ethernet interface for low-speed data transfer to replace RS232 communication. I have used Lantronix before, but that is still more complicated than what I need. I don't need to host a web page, but that might be nice in the future.
Here are some loose requirements:
- No operating system is desired.
- TCP/IP stack handled in C code for minimum development time
- Cheap PHY chip (or even better, no phy chip). Suggestions here?
- No DDR off-board memory
- 10/100 required. Gbit ethernet okay, but I don't want to lock myself into an expensive phy chip or a device that has transceivers
- Able to be used by a higher-end (bigger) Max 10 chip, perhaps the 10M40
- No licenses or OSes to purchase. BTW, is the triple speed ethernet IP provided by Intel free?
I saw the simple socket reference design. This is close to what I need, but I don't want DDR memory. I could change the Qsys project to use on-board memory instead, but I'm not sure how much it really needs. The Max 10 runs out of memory pretty quickly.
I would really appreciate any help. Thanks!
I found the Arrow DECA board, which looks to be designed by Terasic. It has a 10/100 phy. $3 in production, so probably too fancy, but it is cheaper than the 1GBit phys that are being put on some other eval boards.
Good news is that it has a Max 10, and probably some reference designs to get started. Here's the link if anyone is interested:
https://www.arrow.com/en/reference-designs/deca-development-kit-based-on-the-10m50daf484c6ges-max-10-fpga/178fffd04d89cbb578855555cb159a1a
JFarm
I am also looking for a simple Ethernet Interface for the Arrow DECA board that does not use DDR memory. Even if it just for the Max 10 and a different PHY would work.
