Ethernet Products
5668 Discussions
X710 dropping LLDP frames ?
mmich37
We have servers with 2 XL710 quad cards each.
In first, we got this firmware version:
firmware-version: f4.22 a1.1 n04.26 e8000152d
LLDP was working fine, no problem, trames are correctly received.
But after upgrading to (seems to be the last version):
firmware-version: 4.53 0x80001da6 0.0.0
We don't receive any LLDP frames anymore.
It seems that theses frames are dropped by the X710 cards.
I tried to downgrade to 4.42 firmware but ... same thing
The problem occurs on both vSphere 6.0 and Linux (RHEL 6.6) on the 5 servers that have theses ethernet adapter and their firmware updated
We have other cards from other vendor on theses servers that are plugged on the same network equipments and they receive LLDP frames without problems.
Some debug informations (vsphere side, we upgraded the driver to the last version according the HCL, but the problem is the same with the "base" driver):
# lspci|grep Ethernet
0000:02:00.0 Network controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet [vmnic0]
0000:02:00.1 Network controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet [vmnic1]
0000:02:00.2 Network controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet [vmnic2]
0000:02:00.3 Network controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet [vmnic3]
0000:04:00.0 Network controller: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet [vmnic4]
0000:04:00.1 Network controller: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet [vmnic5]
0000:08:00.0 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic10]
0000:08:00.1 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic11]
0000:08:00.2 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic12]
0000:08:00.3 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic13]
0000:0b:00.0 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic6]
0000:0b:00.1 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic7]
0000:0b:00.2 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic8]
0000:0b:00.3 Network controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ [vmnic9]
# vmkchdev -l|grep vmnic6
0000:0b:00.0 8086:1572 8086:0002 vmkernel vmnic6
# ethtool -i vmnic6
driver: i40e
version: 1.3.38
bus-info: 0000:0b:00.0
Some debug informations (Linux side, i40e driver upgraded too, but problem is the same with the "base" driver):
# lspci | grep Ethernet
02:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
02:00.1 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
02:00.2 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
02:00.3 Ethernet controller: Broadcom Corporation NetXtreme BCM5719 Gigabit Ethernet PCIe (rev 01)
04:00.0 Ethernet controller: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet (rev 10)
04:00.1 Ethernet controller: Broadcom Corporation NetXtreme II BCM57810 10 Gigabit Ethernet (rev 10)
08:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
08:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
08:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
08:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
0b:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
0b:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
0b:00.2 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
0b:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
# ethtool -i eth6
driver: i40e
version: 1.3.39.1
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
# ethtool -k eth6
Features for eth6:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-unneeded: off
tx-checksum-ip-generic: off
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on [fixed]
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: on
tx-tcp6-segmentation: on
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off
rx-vlan-offload: on
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on [fixed]
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: off [fixed]
tx-udp_tnl-segmentation: off [fixed]
fcoe-mtu: off [fixed]
loopback: off [fixed]
vSphere says that "Link Layer Discovery Protocol is not available on this physical network adapter"
LLDPD under Linux don't output any informations on neighbors switchs for the XL710's cards
From switch perspective we are seeing the LLDP frame well transmitted on the port !
But when trying to capture LLDP frames both tcpdump under linux (tcpdump -i eth6 -s 1500 -XX 'ether proto 0x88cc') and pktcap-uw under vSphere (pktcap-uw --uplink vmnic1 --ethtype 0x88cc -c 1) never output any frames.
Jesse_B_Intel
LLDP is meant to be handled directly on the NIC in the X710, and the firmware defaults to this feature being on. You can work around the issue (at least under linux) using
# echo lldp stop > /sys/kernel/debug/i40e//command
SYeo3
Valued Contributor I
Hi michelm,
The LLDP may have been disabled when you updated the firmware. I'll check on this further.
Sincerely,
Sandy
mmich37
Hi Sandy,
First, thanks for your reply.
Yes, LLDP seems disabled.
Perhaps did you known how to enable it again ?
I tried to play with some settings thanks to 'ethtool -K ...' but no luck and there's no clear settings about LLDP.
MM.
SYeo3
Hi michelm,
Please refer to "Configuring Link Layer Discovery Protocol agent daemon (lldpad)"
Start lldpad service and configure to start at boot time.
root# service lldpad start
Starting lldpad: [done] [ OK ]
root# chkconfig lldpad on
NOTE: There is no output from this command but it will enable lldpad to automatically start when the system
is booted.
User Guide:
http://www.intel.com/content/dam/www/public/us/en/documents/guides/fcoe-user-guide.pdf http://www.intel.com/content/dam/www/public/us/en/documents/guides/fcoe-user-guide.pdf
Sincerely,
Sandy
mmich37
Hello Sandy,
Same result when installing and enabling some settings thanks to LLDPAD.
LLDP RX frames are never seen from OS side ..
Here what I do (after installing and starting lldpad):
# dmesg | grep i40e|grep eth|grep Link
i40e 0000:08:00.0: eth2: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:08:00.1: eth3: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:08:00.2: eth4: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:08:00.3: eth5: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:0b:00.0: eth6: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:0b:00.1: eth7: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:0b:00.2: eth8: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
i40e 0000:0b:00.3: eth9: NIC Link is Up 10 Gbps Full Duplex, Flow Control: None
# for i in `seq 2 9`; do lldptool set-lldp -i eth$i adminStatus=rxtx ; lldptool -T -i eth$i -V sysName enableTx=yes; lldptool -T -i eth$i -V portDesc enableTx=yes ; lldptool -T -i eth$i -V sysDesc enableTx=yes; lldptool -T -i eth$i -V sysCap enableTx=yes; lldptool -T -i eth$i -V mngAddr enableTx=yes; done
Doing eth2
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth3
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth4
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth5
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth6
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth7
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth8
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
Doing eth9
adminStatus = rxtx
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
enableTx = yes
# /etc/init.d/lldpad restart
Stopping lldpad: [ OK ]
Starting lldpad: [ OK ]
# lldptool get-lldp -i eth6 adminStatus
adminStatus=rxtx
# lldptool -t -n -i eth6
# tcpdump -i eth6 -s 1500 -XX 'ether proto 0x88c
Some informations regarding DCB:
# dcbtool gc eth6 dcb
Command: Get Config
Feature: DCB State
Port: eth6
Status: Device not capable
# dcbtool sc eth6 dcb on
Command: Set Config
Feature: DCB State
Port: eth6
Seems that's impossible to enable it ?
Driver/Frimware version (same as below):
# ethtool -i eth6
driver: i40e
version: 1.3.39.1
supports-test: yes
Tests outputed with eth6 but it's the same result with any other ethernet interface from i40e.
It really seems that LLDP RX Frames are dropped directly inside the NIC (firmware setting to tune ?) whatever the OS (vSphere side, same result, LLDP frames are never received on the ESXi).
MM.
Jesse_B_Intel
mmich37
Great, it's working now.
Perhaps Intel should put this in a documentation somewhere ... ?
Thank you jbrandeb ! :-)
JConn6
This seems to be the root cause of the problem we're having as well. However, it seems that the kernel version we're using (2.6.x) requires a different method to disable the internal LLDP agent. When I attempt to echo 'lldp stop' to the path specified above, I get an error and no matter what I try, I'm unable to issue the command in the manner stated. Does Intel provide *any* documentation on how to disable this internal LLDP agent for Linux 2.6.x and 3.x?
Also asked:
http://serverfault.com/questions/775980/disable-internal-intel-x710-lldp-agent centos6 - Disable internal Intel X710 LLDP agent - Server Fault
TIA, Jim
JConn6
Found the steps I needed to make the above (correct) step work. Please follow the link to ServerFault for the steps required if you're having the same issues. For the record, I'm quite disappointed in Intel for not making this a way more transparent process/issue.
oroma1
I am having the same problem. I use a XL710 card in HP DL380 servers, running a Debian 7 OS.
We found out the card do not bring LLDP packets to the Linux stack, and discard it. This behavior is different from X520 cards which pass the LLDP packets to the linux stack.
The work around like '# echo lldp stop > /sys/kernel/debug/i40e//command' works, but we cannot do that on production systems.
Could intel provide some way to set this value in a proper manner (like with ethtool) in the next driver version? Or simply change the default value so that the default behaviour is the same as X520 cards.
Thanks in advance.
Olivier
Is there a way to do this from esxi? I need esxi to exchange lldp info with our switches for our SDN product to do its magic. ESXi is currently showing that the physical adapter is not lldp capable. Updating firmware and driver to the latest did not help.
Same issue with me - X710 not able to transmit CDP or LLDP on ESXi 6.5 on a Dell R730XD
Product: VMware ESXi
Version: 6.5.0
Build: Releasebuild-5224529
Update: 0
Patch: 15
X710
Firmware: 16.5.20
Driver: 1.4.28
It was somewhat frustrating to discover that as this is a Dell OEM X710 the only way to upgrade the firmware was via the Dell Lifecycle controller process. Downloading from Intel directly didn't work, but no error messages saying why were produced. Didn't find this information anywhere on Dell or Intel websites related to this X710 NIC.
--Rob.
ken1
Disabling the LLDP agent under ESXi:
esxcli system module parameters set -m i40en -p LLDP=0,0,0,0
Reference:
https://thevirtualist.org/enabling-lldp-for-intel-x-in-esxi/
best regards,
Ken
