Ethernet Products
Speed setting
NRock
I have installed http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18725&lang=eng PROWinx64.exe. in Windows 7 64 bits and trying to set speed of all the installed Intel NICs in the PC using PROSETCL. I use the Adapter_EnumerateSettings 3 command to get the settings of the NIC. I see *SpeedDuplex - Auto Negotiation.
When i try to get the setting using: PROSetCL.exe Adapter_GetSetting 3 *SpeedDuplex
I get the following Error: Setting name not found: *SpeedDuplex
Does anyone know why it Settcan not find the setting name, although, is right.
