Ethernet Products
5212 Discussions
Still no bueno 24.2
CZ
Intel 210.pngTeam is created without issue on dual I210's. Primary and Secondary Adapter are set without issue.
No traffic passes afterwards. No access to network or internet.
After Removing Team, Nic 1 says I need to log in to my ISP to access the internet if it is the only NIC enabled and gives the little Globe icon in task bar. NIC #2 connects just fine if it is the only NIC enabled.
Any help is appreciated. Workjed fine before latest patch of 1903.
CZ
After more pokinmg at this, checking switch, LAGS, etc. I found that my cable modem had set itself to block communication from the MAC assigned to the team. I have removed thast and all is working now. Thank you again for the reply.
Z
Mike_Intel
Hello CZ,
For me to further help you, I need to gather the following details.
  1. What is your OS?
  2. Are you using an on-board NIC?
  3. What is the model of your board or system?
  4. What is the driver version used?
  5. You mentioned that there is no issue before updating to 1903, have you tried checking the issue with Microsoft if they have known issue?
If you have questions, please let us know.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
CZ
Thanks for the reply.
  1. Windows 10 Pro x64, Version 10.0.18362 Build 18362
  2. Dual on-board I210's
  3. ASUS P9X79-E WS
  4. Driver Version 24.2 (12.18.9.1)
  5. 1903 was working fine with 24.1 until the last 1903 roll up patch. After that, this behavior began.
Thank you.
Z
CZ
Z
