Ethernet Products
5821 Discussions
Support of one-step DM of PTP in I210 NIC
Kiranchaganti
Hi All,
How can we check whether I210 NIC cards support one-step DM in PTP.
I checked using Ethtool in Linux machine.
Command used : Ethtool -T <interface name>
It didn't mentioned about one-step ptp support
Do we have any other way to check ?
Is it necessary to load any specific for PTP to work in Linux if we are using I210 NIC.
abcd@root1234:~$ ethtool -T ens4
Time stamping parameters for ens4:
Capabilities:
hardware-transmit
software-transmit
hardware-receive
software-receive
software-system-clock
hardware-raw-clock
PTP Hardware Clock: 0
Hardware Transmit Timestamp Modes:
off
on
Hardware Receive Filter Modes:
none
all
B_Y
Hi Sai Kiran Chaganti,
Can you share following information for us to further check your request?
-OS version and Build
-System model
-Model of Intel Ethernet Server Adapter I210
Note: For Original Equipment Manufacturer(OEM) version of Ethernet adapters, we'd like to set your expectation that we have a limited support it would be best if you can also get in touch with OEM company.
You may check article below which states "HW Timestamp is supported on e1r devices (I210, I211 and I350) for Windows"
https://www.intel.com/content/www/us/en/support/articles/000089268/ethernet-products/gigabit-ethernet-adapters-up-to-2-5gbe.html
We will follow up after 3 business days in case we don't hear from you.
BY_Intel
Intel Customer Support
Kiranchaganti
Hi @B_Y
OS version and Build:
abcd@root1234:~$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 18.04 LTS
Release: 18.04
Codename: bionic
abcd@root1234:~$ uname -r
6.1.0-060100rc5-generic
System model:
abcd@root1234:~$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 26
Model name: Intel(R) Xeon(R) CPU W3565 @ 3.20GHz
Stepping: 5
CPU MHz: 1600.011
CPU max MHz: 3193.0000
CPU min MHz: 1596.0000
BogoMIPS: 6400.13
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 8192K
NUMA node0 CPU(s): 0-3
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ht tm pbe syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc cpuid aperfmperf pni dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm dca sse4_1 sse4_2 popcnt lahf_lm pti ssbd ibrs ibpb stibp tpr_shadow vnmi flexpriority ept vpid dtherm ida flush_l1d
abcd@root1234:~$
28:00.0 Ethernet controller: Intel Corporation I210 Gigabit Network Connection (rev 03)
Subsystem: Hewlett-Packard Company Ethernet I210-T1 GbE NIC
Physical Slot: 4
Flags: bus master, fast devsel, latency 0, IRQ 34
Memory at e5000000 (32-bit, non-prefetchable) [size=1M]
Memory at e5100000 (32-bit, non-prefetchable) [size=16K]
Capabilities: <access denied>
Kernel driver in use: igb
Kernel modules: igb
B_Y
Thank you for the information,
I may need your help to elaborate or clarify the meaning of "One-step DM or PTP support" as it may seem something unusual.
Used the article for your refence:
https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/6/html/deployment_guide/s1-using_ptp
We would like to know if you’ve been able to try our suggestion above.
In case you did, we would highly appreciate if you would let us know the outcome of these.
We will be waiting for your response.
BY_Intel
Kiranchaganti
Hi @B_Y
My doubt is does intel I210-t1 support hardware time stamping or not.
As I could not find it working with one-step delay mechanism in PTP,(One-step DM works if I210 supports hardware time stamping).
As I verified two step delay mechanism working for I210-t1 which uses software time stamping.
Please clarify on hardware time stamping support on i210-T1 in Linux.
B_Y
We got 2 articles for your reference in relate to i210, and IEEE15888
https://www.intel.com/content/dam/www/public/us/en/documents/faqs/ieee1588-faq.pdf
https://www.intel.com/content/www/us/en/content-details/334026/intel-ethernet-controller-i210-i211-faq.html?wapkw=334026
There is also some discussion from another platform:
https://github.com/AVnu/OpenAvnu/issues/623
Please have a look and let us know if it helps. Otherwise, you can share with us at which stage of script that need further assistance, so we can check with our internal engineer.
BY_Intel
B_Y
We would like to follow up on your case, In our last interaction we provided you with the following suggestion:
Looking forward to hear from you.
BY_Intel
B_Y
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post.
Thank you.
BY_Intel
B_Y
Since we have not seen an update for several days, if you need any additional information, please submit a new question as this thread will no longer be monitored.
BY_Intel
