- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
We are using Intel Corporation Ethernet Controller E810-XXV for SFP [8086:159b] in our workload mostly as transit card for client's traffic.
We are facing issue with RX TCP packets with QinQ are having incorrect checksum, going through the NIC and increasing RX ERR counter in the system.
On our nodes we are using Canonical Ubuntu as OS and we haven't found a way yet how to disable TCP checksum offload for RX packets, although you are providing such functionality under Windows using your PROSet tool(here is the example https://edc.intel.com/content/www/us/en/design/products/ethernet/adapters-and-devices-user-guide/tcp-checksum-offload-ipv4-and-ipv6/)
Is there a way to disable TCP checksum offload for RX packets under Linux? Perhaps there is some raw command you can exectue or some tool you can use?
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hello zukimorimkato,
Greetings!!
Thank you for writing to us. You can try below :
Command: ethtool -K rx on|off
Please write to us if you have any other concerns.
Subhashish_Intel.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thank you for your prompt reply.
In our case, we don't need to disable TCP checksum offload for all rx packets in the system, as we still would like to have option to monitor other, not client traffic packets, it is used mostly, but not in its entirety for that. We'd like to know if this particular option which is available under IntelPROSet in Windows can be used for ethtool in Linux?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Alexander,
Greetings for the day!
We would like to inform you the ethtool should already be installed as part of the OS. We recommend you to run the below command and please let us know the status to check and assist you further.
Thank you for your understanding!
Poojitha
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Greetings !!
Thank you for clarifying further on the issue. We are checking on this internally and we will update you at earliest.
Thank you for choosing Intel.
Subhashish_Intel.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Greetings!!
Apologies for the delayed response. We would recommend you to share with us the dmesg log surrounding the time when you were seeing the issues.
Also, please share with us output for the commands :
"uname -a"
"modinfo ice"
Looking forward to hear from you.
Subhashish.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Greetings !!
This is a follow up regarding the reported issue. We would like to know whether you got any opportunity to review the plan of action shared.
Please write back to us for any other query.
Subhashish_Intel.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Greetings for the day!!
Hope you are doing well.
This is Second follow up regarding the reported issue. We would like to know whether you got any opportunity to review the plan of action shared.
Subhashish_Intel.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
How to identify the full name/description of my Intel(R) Ethernet 25G 2P E810-XXV Adapter.
Question: Is it ?
- Intel Ethernet Network Adapter E810-XXVDA2: which supports dual 25GbE ports.
or
- Intel Ethernet Network Adapter E810-XXVAM2: which supports dual 25GbE ports with advanced offloads.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Upon reviewing the PCI IDs associated with your Intel Ethernet Network Adapter (Device ID: 159B, Sub Device ID: 0002, Sub Vendor ID: 8086), it has been identified as the Intel(R) Ethernet 25G 2P E810-XXV Adapter.
Identifying the exact model, such as E810-XXVDA2 or E810-XXVAM2, depends on the suffix following the model number. E810-XXVDA2 typically indicates a basic adapter with dual 25GbE ports, while E810-XXVAM2 usually indicates an adapter with advanced offloads in addition to dual 25GbE ports. For confirmation, please refer to the product label or documentation that came with your adapter, as PCI IDs alone do not specify the variant.
If you need more help or have questions, please don't hesitate to contact us. We are happy to assist you.
Thank you for choosing Intel products and services.
Manoranjan.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks for the reply @ManoranjanDas ,
I don't have the physical adapter with me, so won't be able to check Product Label or documentation. Is there any other way to identify or get a specific document?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi zukimorimkato,
Regarding your query please find the below link to know better about the both product.
Please find the details about the Intel® Ethernet Controllers E810-XXVAM2 and E810-XXVDA2 using the link below, where you will also find the datasheets.
Manoranjan.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Thanks @ManoranjanDas .
Also, correct me if I'm wrong, according to the documentation links you shared me -> that implies:
E810-XXVAM2 is an Ethernet Controller
and
E810-XXVDA2 is an Ethernet Network Adapter or NIC
And as per the specifications I have: my NIC should be E810-XXVDA2, which is using Controller: E810-XXVAM2.
Right?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Roman,
Thank you for your message. Regarding the issue you mentioned, I can see that three cases are currently open. Could you please confirm if we can close these two cases 06297118 and 06297453 as duplicates?
Additionally, please respond regarding case 06274485 so that we can assist you further. Kindly refrain from creating any new cases. If you have any more questions or need further assistance, please don't hesitate to contact us.
Manoranjan.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi Nakul,
Greetings!
This thread is related to a different query. Mr. Nakul, please create a new thread for your current issue, as we are unable to proceed with this one.
Manoranjan
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
This is the third follow-up regarding the reported issue. We're committed to ensuring a swift resolution and would greatly appreciate any updates or additional information you can provide.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience.
Subhashish.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Hi @ManoranjanDas
Sorry for asking on the different thread, actually I opened a thread but didn't get any reply so thought to ask here.
Can we discuss it at : https://community.intel.com/t5/Ethernet-Products/How-to-identify-full-name-of-Intel-R-Ethernet-25G-2P-E810-XXV/m-p/1617257/thread-id/38890
Nakul
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
