Ethernet Products
5666 Discussions
Teaming not working for Windows 10 x64 Ent 1809 build version Ethernet Adopter is Intel X520-2 Installed Drivers version is 23.5.0.0 Before this tried with 23.5.1 no luck can any one help on this with proper solution ?
MKals1
Previous OS windows 7 was working fine.
Daniel_D_Intel1
Hello MKals1, Thank you for posting in Intel Ethernet Communities. Is this a fresh Install of Windows 10 1809? Are you creating Teams in PowerShell? If you are using PowerShell already, are you getting an error or hanging when you create a team? Please use the following procedure: 1. Open Windows Powershell as administrator. 2. Import the PROSet Powershell* module using this command: Import-Module -Name "C:\Program Files\Intel\Wired Networking\IntelNetCmdlets\IntelNetCmdlets" 3. Type "Get-IntelNetAdapter" to display the name of your network adapter. 4. Type "New-IntelNetTeam" to initiate the creation of a Team. See the following for details: https://www.intel.com/content/www/us/en/support/articles/000023545/network-and-i-o.html https://www.intel.com/content/www/us/en/support/articles/000031823/network-and-i-o/ethernet-products.html?wapkw=23.5+release&language=en_US Best regards, Daniel D Intel Customer Support
MKals1
Hello Daniel,
thanks for reply
this is totally fresh install of windows 10 1809 version.
i am not creating teams in powershell .
so kindly help me how to make team in GUI mode ?
ANS is not showing any kind of team option there ?
i already provided drivers details.
awaiting for your reply as we are stuck and due to this business is hampering a lot.
MAYURESH
Daniel_D_Intel1
Hello MKals1, Thank you for the reply. Unfortunately the usual GUI from Device manager is not supported in this version of Windows 10 and later versions. Currently Teams can be set up through PowerShell as described above. A GUI using PROSet adapter configuration utility is planned, but we have no release date yet. We would recommend using PowerShell. If you have any issues let us know, and we will provide assistance. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
Daniel_D_Intel1
Hello MKals1, Please let us know if you were able to create the teams using PowerShell. If you have any other questions please ask. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
MKals1
Hi, Kindly close this ticket thanks for your time. But still it’s not working for win 10 1809 ver. Regards MAYURESH Regards, [cid:image010.jpg@01D454A9.81E7DF10] MAYURESH KALSEKAR IT GNS Support Technician – Pune Studio M : +91-9881998280 Ubisoft.com<https://www.ubisoft.com/en-US/studio/pune.aspx>
Daniel_D_Intel1
Hello MKals1, Thank you for the reply. If you are having an error or hanging issue when initiating teams please check the following thread for updates: https://forums.intel.com/s/question/0D70P000006Bm8lSAC/ Let us know if you have any other questions. Best regards, Daniel D Intel Customer Support Under Contract to Intel Corporation
