Ethernet Products
5736 Discussions
Thermal data and spec sheet for WGI219LM[VER.A0,SLKJ2]
Don62
I need a spec sheet for WGI219LM[VER.A0,SLKJ2]as well as usable thermal specifications such as the maximum recommended case temperature or the maximum recommended junction temperature and theta Jc.
Poojitha
Hi Don62,
Greetings for the day!
Thank you for your response. We would like to request you to check the below link and kindly download the data sheet (Supplemental Information>> Datasheet>> View now>> Check the downloaded file) to get complete 'thermal specification' information.
https://www.intel.com/content/www/us/en/products/sku/82185/intel-ethernet-connection-i219lm/specifications.html
If you have any questions or doubts, please reach out to us. We are happy to help you.
Thank you for your understanding!
Poojitha
Poojitha
Hi Don62,
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Poojitha N
Don62
Yes. Thank you.
Theta Jc of 15.1 C/W and Max. Junction temperature of 119 degrees C.
I did notice 2 things.
The data sheet has a floating Max. Junction temperature. This should be a set temperature that take into account the material breakdown of the component, operational integrity, and fatigue over time.
The data sheet also shows that the Junction temperature increases when the air flow increases. This seems inverted.
Thanks again,
Don
Poojitha
Hi Don62,
Thank you for your response. Please let us know if you need any additional information to assist you further
Thank you for your support!
Poojitha N
Poojitha
Hi Don62,
We are following up on your case Please let us know if you require any additional information or assistance from our end. We are happy to help you.
Poojitha N
