Ethernet Products
5821 Discussions
Unable to delete DPDK DDP GTP Profile in Intel X710 NIC
Harrish
Hi Team,
I have configured DDP GTP Profile (gtp.pkg) downloaded from https://downloadcenter.intel.com/download/27587 and followed below steps:
testpmd> stop
testpmd> port stop 0
testpmd> ddp add 0 /usr/lib/firmware/intel/i40e/ddp/gtp.pkg
And the get list also retrieves the profile properly as below:
testpmd> ddp get list 0
Profile number is: 1
Profile 0:
Track id:     0x80000008
Version:      1.0.4.0
Profile name: GTPv1-C/U IPv4/IPv6 payload
Issue-1 : But when the packets are parsed using DPDK APIs the header fields are still classified as unknown.
Issue-2: We are unable to remove/delete the ddp profile configured and observing the below error
testpmd> ddp del 0 /usr/lib/firmware/intel/i40e/ddp/gtp.pkg
rte_pmd_i40e_process_ddp_package(): Failed to write profile for delete.
Failed to delete profile.
testpmd>
NIC Details:
dpdk-devbind.py -s
Network devices using DPDK-compatible driver
0000:82:00.0 'Ethernet Controller X710 for 10GbE SFP+ 1572' drv=igb_uio unused=i40e,vfio-pci,uio_pci_generic
Could you please help us in resolving the issue with your inputs.?
Thanks in advance,
Regards and Thanks,
Harrish.S.J,
Member Technical Staff,
Aviz Networks
B_Y
Hello @Harrish,
For this particular issue, kindly reach out DPDK.org or open an IPS case at IPS Support.
Please refer the link below on how to reach the IPS support
How to Register and have Access to Intel® Premier Support
Thank you.
BY_Intel
Intel Customer Support
bai_xue
Hi ,Harrish
 I also encountered the same problem as you. Two years later, I came across your question. Can you tell me how to solve it? Thanks
