Ethernet Products
Avisos
5697 Discusiones
VLAN creation on Windows 10 Enterprise TP
CÒó
Novato
26.853 Vistas
Hello, there.
This morning I upgraded my fully functionnal Windows 8.1 Enterprise installation to Windows 10 Technical Preview. Before that, I downloaded the Intel Network Adapter Driver from this website, version 20.1, for Windows 10 64 bits. After the driver installation, I had the VLANs tab in the network card properties. However, i'm unable to create a VLAN. The network card is automatically disabled then I receive an error message saying this (translated from french):
One or more vlans could not be created. Please check the adapter status and try again.
The window freezes and I have to force-close it. 802.1 option is of course enabled in the Advanced options tab. The event viewer always shows the same error when I try to create a VLAN:
Nom de l'application défaillante NCS2Prov.exe, version : 20.1.1021.0, horodatage : 0x554ba6a4
Nom du module défaillant : NcsColib.dll, version : 20.1.1021.0, horodatage : 0x554ba57d
Code d'exception : 0xc0000005
Décalage d'erreur : 0x0000000000264064
ID du processus défaillant : 0x19d4
Heure de début de l'application défaillante : 0x01d0ada33fd50576
Chemin d'accès de l'application défaillante : C:\Program Files\Intel\NCS2\WMIProv\NCS2Prov.exe
Chemin d'accès du module défaillant: C:\WINDOWS\SYSTEM32\NcsColib.dll
ID de rapport : eefb5842-9220-4bad-93d3-774828c5736e
Nom complet du package défaillant :
ID de l'application relative au package défaillant :
I already tried to uninstall all the packages and drivers related to the network card. I deleted fantom network cards then cleaned up the registry. I tried to set some compatibility options to the given executable file, with no success. I tried to reinstall the driver with Drivers Signature disabled, tried to disable IPv4/IPv6 from the network card before trying to add a VLAN... I tried everything I found on Google.
Could someone help me, please?
0 kudos
61 Respuestas
ATV
Principiante
9.020 Vistas
The same problem with i217-v for ASUS Z-87 PLUS
I have in the events of this message
Device PCI \ VEN_8086 & DEV_153B & SUBSYS_859F1043 & REV_05 \ 3 & 11583659 & 0 & C8 require further installation.
st4
Nuevo Colaborador III
9.020 Vistas
Hi Everyone,
Thank you for the post, we will further check on this.
Solykz,
Can you give me the exact network adapter model?
What is the system you used? (e.g Asus? )
wb
CÒó
Novato
9.020 Vistas
Hello WB,
I've got an Intel L217-LM network adapter on a DELL Precision M4800 laptop.
Yesterday night I made a full reinstall (no upgraded from 8.1 like previously) of the 10147 build, with no luck. Everything worked fine on Windows 8.1.
Thanks for any help you could provide.
Chris.
st4
9.020 Vistas
Hi Chris,
Thank you for the information. Have you checked with Dell* support also if they have any customized driver specifically for Windows* 10 OS on your laptop?
wb
CÒó
Novato
9.020 Vistas
Hello WB,
No, I didn't. The support page (http://www.dell.com/support/home/us/en/19/product-support/product/precision-m4800-workstation/drivers Product Support | Dell US) don't provide any Windows 10 driver.
Thus the Windows 8.1 driver didn't, as far as I know, let the ability to create VLANs.
Chris.
st4
9.020 Vistas
Hi SolykZ,
Thank you for the update. Let me check on this.
rgds,
wb
KBott
Principiante
9.020 Vistas
the 20.1 driver kit is supposed to support Windows 10.
However, i tested and failed for VLANs......
KBott
Principiante
9.020 Vistas
testing the the Intel 20.1
no VLAN creation working
Looks like the WMIProvider issues wrong Parameters
Faulting application name: NCS2Prov.exe, version: 20.1.1021.0, time stamp: 0x554ba6a4
Faulting module name: NcsColib.dll, version: 20.1.1021.0, time stamp: 0x554ba57d
Exception code: 0xc0000005
Fault offset: 0x0000000000264064
Faulting process id: 0xcb4
Faulting application start time: 0x01d0b26a607942ee
Faulting application path: C:\Program Files\Intel\NCS2\WMIProv\NCS2Prov.exe
Faulting module path: C:\WINDOWS\SYSTEM32\NcsColib.dll
Report Id: 969b81c4-18d4-49af-8578-096383f4fbb6
Faulting package full name:
Faulting package-relative application ID:
st4
9.020 Vistas
Hi HyperV_guy,
Thank you for sharing the additional info, we are checking on this.
rgds,
wb
st4
9.020 Vistas
Hi Solykz and HyperV_guy,
Further checking since Windows 10 is not officially released yet, only a TP version, please have this tested when it is officially released.
wb
CÒó
Novato
9.020 Vistas
Hello WB,
That must be a joke, right? Because as far as I know, Intel himself provided this driver, knowing that Windows 10 was not officially released.
So, what? Hasn't the driver be tested before its availability to download? Is it a marketing move maybe, like "We already provide Windows 10 stuff"?
Well, I'll wait until the RTM. But please be kind enough to remove the "Windows 10" item from the Operating Systems drop-down menu, because that's not fair to let users think that Intel already provide functionnal drivers to this "not officially released yet" OS. ;-)
Have a good day anyway.
Chris.
st4
9.020 Vistas
Hi SolykZ,
Thank you for the feedback.
rgds
wb
st4
9.020 Vistas
Hi SolykZ,
Good day. Just to let you know this is a Microsoft* issue and they are working on it. Let us wait for the official release.
Hope this clarifies.
rgds,
wb
KBott
Principiante
9.020 Vistas
wb_intel, with the official build now released, was there a chance to investigte further from intel ?
Other Bridging eg, vmware or stuff like winpcap seem to work now.
Has intel tested VLAN already or is this up to the community ?
st4
8.745 Vistas
Hi HyperV_guy & all,
Further checking this is a Microsoft issue and we already reported to Microsoft*, currently you may revert back to previous operating system or wait until the fix release by Microsoft*. Thanks.
rgds,
wb
Jgoos
Principiante
8.745 Vistas
Hi all,
I have just seen this article I am using windows 10 Entreprise since on month (release date), I upgrade from windows 8.1 and vlan features is not working anymore, I removed microsoft drivers and try to upgrade to intel 20.3 drivers that gave me for my nic driver version : 12.12.140.22 I reset all my vlan configuration, and when I try to add the first vlan I get the attached message in French (at least on vlan....) and the first virtual network card created is a : Intel(R) Advanced Network Services Virtual Adapter and no vlan added the second time I add the same vlan ID a new network card is created : Intel(R) 82579LM Gigabit Network connection - VLAN : VLAN2090 but no vlan is added
my configuration is : windows 10 on HP laptop 2570p my embeeded nic is : Intel 82579LM
if I can help or if there is any workaround I am interested in because I cannot use my office connection because I am connected to a lot of networks with this vlan feature
st4
8.745 Vistas
Hi tacticman,
So far what is new in the driver 20.3 are found as below: (https://downloadmirror.intel.com/25016/eng/readme.txt https://downloadmirror.intel.com/25016/eng/readme.txt), as this is a Microsoft issue and we have already reported to Microsoft:
What's New in This Release
- Support for the Intel(R) Ethernet Controller X710/X557-AT 10GBASE-T
- Support for FCoE and DCB functionality in Microsoft* Windows PowerShell*
- Support for Data Center Bridging (DCB) on the Intel(R) X710 Converged Adapter
when running Windows and Linux
- Support for Data Center Bridging (DCB) on the Intel(R) XL710 Converged Adapter
when running Linux
- The prefix for Intel(R) PROSet for Windows* Device Manager ANS teams has
changed from "TEAM : " to "TEAM: ". Please update your scripts accordingly.
Have you also tried the Microsoft patch on the website?
https://downloadcenter.intel.com/download/25016/Network-Adapter-Driver-for-Windows-10 Intel® Download Center
rgds,
wb
Jgoos
Principiante
8.745 Vistas
Hi wb,
thanks for the reply, the microsoft update KB3081448 has been installed automatically on august 28th so before I tried to install vlan features and even with the MS patch it's still doesn't work for me.
rgds
yann
st4
8.745 Vistas
Hi Tacticman,
Thank you for the update. Further checking, creating Intel® ANS teams and VLANs on Microsoft* Windows* 10 is currently not supported. We expect that ANS will be supported on Microsoft* Windows* 10 client in a future release. We apologize for any inconvenience this might have caused.
rgds,
wb
WHeul
Principiante
8.745 Vistas
wb_Intel wrote:
Hi Tacticman,
rgds,
wb
Any news on this? Any options from Intel or Microsoft?
Responder
