Ethernet Products
5821 Discussions
What is the main different on Intel I350 & Intel ET2
Dear All,
I am doing some research recently and we are looking some Network Card for our iSCSI Storage (MD3220i)
What is the different on the Intel I350 & Intel ET2 Network card?
What I have see the Intel I350 seem have iSCSI performance enhancement, how about ET2?
Which Network Card should be best for connected with the iSCSI Stroage? (Quad Port Network Card with 1Gbit)
Kelvinyasu
Mark_H_Intel
Either quad port adapter is suitable for iSCSI, but in a http://ark.intel.com/compare/49187,59063 side-by-side comparison, you will notice some advantages to the specifications of the Intel® Ethernet Server Adapter I350-T4. The Intel Ethernet I350 server adapters are the newest, premium gigabit adapters offered by Intel. The Intel® Gigabit ET2 Quad Port Server Adapter was the best Intel Ethernet gigabit adapter for storage when it was launched, but the technology used is older and the power consumption will be higher.
If you have a tested system configuration using the Intel Gigabit ET2 Quad Port Server Adapter, I would say stick with the design that you know works. If you are planning a new system, then I would recommend the Intel Ethernet Server Adapter I350-T4. The newer adapter will give you a design with that includes the latest technology.
I hope this helps.
Mark H
Added via edit: I should also have mentioned that if you anticipate moving to 10 Gigabit Ethernet in the near future, you might want to look at the http://ark.intel.com/products/52196/Intel-Ethernet-Server-Adapter-X520-T2 Intel® Ethernet Server Adapter X520-T2. This adapter will work on your Gigabit network, but gives you the capability of moving to 10-gigabit and keeping the same adapter.
