Ethernet Products
5658 Discussions
When installing Ubuntu OS in this environment, the network continuously occurs Rx drop.
libero11
1. H/W Information
The NIC information installed on the SuperMicro 740GP-TNRT is as below.
1) Onboard : Dual LAN with Intel® X550 10GBase-T Ethernet Controller
2) PCI Slot
- 4x 10GbE RJ45, PCI-E x8, Intel XL710 (AOC-STG-i4T)
2. OS Information
- Ubuntu LTS 20.04 (18 version also has same issue.)
3. error issue
- When installing Ubuntu OS in this environment, the network continuously occurs Rx drop.
4. Verification method
1) Same issue reoccurred in same environment: device connection between Server and Switch (Server<->Switch) --> The drop occur in ‘Bond’ configuration with 2x 4Port 10Gb NIC, and drop occur also in eno1 which is Onboard.
: This issue occur in all Intel NIC.
: It also occur in single network port, therefore we can’t determine as a bonding configuration error.
: Carried out both MTU modification and autoneg alternation test.
- Continuous ‘Rx drop’ occur when connecting same server (supermicro 740GP-TNRT) eno1(Onboard)<-> Cisco 2960(Temporary switch for verification test)
2) The above ‘Drop’ issue doesn’t occur in verification test between existing server (DELL R740 : CGR81D3) eno1(Onboard) <-> Switch(NETGEAR XS728T)
3) The above ‘Drop’ issue doesn’t occur in verification between Existing Server(DELL R740 : CGR81D3) eno1(Onboard) <-> Switch Cisco 2960(Temporary switch for verification test)
** The ‘Rx drop’ occurs only on SuperMicro servers, when we do the verification test in all same network environments(where the only difference is in a server node)
4) ‘Rx drops’ do not occur in the same H/W environment in Redhat 7.x and CentOS 7.x except Ubuntu.
5) Reference information
Operating system: Ubuntu 20.04
ethtool -l eno1
This only occurs between the intel NIC and Ubuntu (the symptoms are the same in 18.x).
Please suggest a solution to solve this issue.
Jong-Hwa Lee (libero11@open-network.co.kr)
Mike_Intel
Hello libero11,
For us to further check the issue, please provide the following details.
  1. What is the OS installed on this system before?
  2. Can you provide the link of the driver used?
  3. Aside from installing Redhat 7.x and CentOS 7.x, what are the other troubleshooting steps that you tried so far?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Caguicla_Intel
Hello libero11,
Good day!
This is just a follow up to check if you received our initial response. If yes, please confirm and provide the information requested for us to proceed checking your query.
Awaiting to your reply.
Should there be no response from you, I’ll make sure to reach out after 3 business days.
Crisselle C.
Caguicla_Intel
Hello libero11,
How are you doing?
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
