When we are using the network port of intel I350-T4 for OCP 3.0 as the shared BMC network port, we find that when the server is restarted, there will be a lot of network alarm information system info:ethX lost carrier information,
no matter which network port we share, there will be such warning information. It was confirmed by our BMC engineer that this information came from the network port, so why did the network port report such information? The frequency of each occurrence is different and irregular. What is the reason for this alarm message?
(Note: When you enter the operating system, this information is gone.)
Hello kolink,
Thank you for your posting in Intel Ethernet Communities.
Regarding your inquiry, could you please share with us the following information to proceed further:
1) ethtool eth0 and eth1
Irwan_Intel
Thank you very much for your response. The following is the information obtained by ethtool and SSU.
# SSU Scan Information
Scan Info:
Version:"1.0.0.0"
Scan Date:"2024/06/05"
Scan Time:"15:18:18"
## Scanned Hardware
Computer:
BaseBoard Manufacturer:"GIGABYTE"
Bios Mode:"UEFI"
Bios Version/Date:"F18,12/01/2022"
CD or DVD:"Not Available"
Platform Role:"Linux localhost.localdomain 3.10.0-1160.el7.x86_64 #1 SMP Mon Oct 19 16:18:59 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux"
Processor:"Intel(R) Xeon(R) Gold 5315Y CPU @ 3.20GHz"
Serial Number:"GNGEUU112A0006"
SMBIOS Version:"3.3.0"
Sound Cards:"Not Available"
System Manufacturer:"GIGABYTE"
System Model:"R282-2O0-00"
System Type:"x64-based PC"
- Display
- "ASPEED Technology, Inc. ASPEED Graphics Family (rev 52) (prog-if 00 [VGA controller])"
Adapter RAM:"Memory at 9a000000 (32-bit, non-prefetchable) [size=16M]"
Adapter RAM:"Memory at 9b000000 (32-bit, non-prefetchable) [size=256K]"
Capabilities:"[40] Power Management version 3"
Capabilities:"[50] MSI: Enable- Count=1/4 Maskable- 64bit+"
Caption:"ASPEED Technology, Inc. ASPEED Graphics Family (rev 52) (prog-if 00 [VGA controller])"
Device ID:"1458:1000"
Driver:"ast"
Driver Path:"/lib/modules/3.10.0-1160.el7.x86_64/kernel/drivers/gpu/drm/ast/ast.ko.xz"
Driver Provider:"Dave Airlie"
Driver Version:""
Flags:"medium devsel, IRQ 17, NUMA node 0"
I/O Ports:"I/O ports at 6000 [size=128]"
Manufacturer:"ASPEED Technology, Inc. [1A03]"
Power Management Capabilities:"Power Management version 3"
Refresh Rate - Current:" 1360x768 60.02* "
Resolution:" 1360x768 60.02* "
- Memory
Physical Memory (Available):"60651 MB"
Physical Memory (Installed):"63869 MB"
Physical Memory (Total):"76081 MB"
- "DIMM_P0_A0"
Capacity:"32 GB"
Configured Clock Speed:"Not Available"
Configured Voltage:"1.2 V"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First Position"
Locator:"DIMM_P0_A0"
Manufacturer:"Samsung"
Maximum Voltage:"1.2 V"
Minimum Voltage:"1.2 V"
Part Number:"393A4K40EB3-CWE"
Serial Number:"2141-481C1D62"
Type:"Synchronous Registered (Buffered)"
- "DIMM_P1_I0"
Capacity:"32 GB"
Form Factor:"DIMM"
Locator:"DIMM_P1_I0"
Serial Number:"2141-481A95F6"
- Motherboard
Product:"MR92-FS1-00"
Serial Number:"MHWN6300004"
Version:"01000100"
- Networking
- "Intel Corporation I350 Gigabit Network Connection (rev 01)"
Supports auto-negotiation:"Yes"
Advertised auto-negotiation:"Yes"
Auto-negotiation:"on"
Availability:"eno1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
Capabilities:"[50] MSI: Enable- Count=1/1 Maskable+ 64bit+"
Capabilities:"[70] MSI-X: Enable+ Count=10 Masked-"
Capabilities:"[a0] Express Endpoint, MSI 00"
Capabilities:"[100] Advanced Error Reporting"
Capabilities:"[140] Device Serial Number 74-56-3c-ff-ff-58-17-9f"
Capabilities:"[150] Alternative Routing-ID Interpretation (ARI)"
Capabilities:"[160] Single Root I/O Virtualization (SR-IOV)"
Capabilities:"[1a0] Transaction Processing Hints"
Capabilities:"[1c0] Latency Tolerance Reporting"
Capabilities:"[1d0] Access Control Services"
Caption:"Not Available"
Default IP Gateway:"Not Available"
DHCP Enabled:"Yes"
DHCP Lease Expires:"Not Available"
DHCP Lease Obtained:"Not Available"
DHCP Server:"Not Available"
Driver:"igb"
Driver Path:"/lib/modules/3.10.0-1160.el7.x86_64/kernel/drivers/net/ethernet/intel/igb/igb.ko.xz"
Driver Provider:"Intel Corporation, <e1000-devel@lists.sourceforge.net>"
Driver Version:""
Duplex:"Unknown! (255)"
Firmware Version:"1.63, 0x800009fa"
Interface:"eno1"
I/O Ports:"Not Available"
IP Address:"Not Available"
IP Subnet:"Not Available"
MAC Address:"74:56:3c:58:17:9f"
Manufacturer:"Intel Corporation"
Net Connection ID:"Not Available"
Port:"Twisted Pair"
Power Management:"Supports Wake-on: pumbg"
Power Management:"Wake-on: g"
Speed:"Unknown!"
Supported link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
Advertised link modes:"10baseT/Half 10baseT/Full, 100baseT/Half 100baseT/Full, 1000baseT/Full"
Partner advertised link modes:"Not Available"
Availability:"eno2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Interface:"eno2"
MAC Address:"74:56:3c:58:17:a0"
Port:"Twisted Pair"
Speed:"Unknown!"
Availability:"ens9f0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
Capabilities:"[140] Device Serial Number 68-05-ca-ff-ff-c4-5e-8e"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Firmware Version:"1.63, 0x800010c1, 1.2228.0"
Interface:"ens9f0"
MAC Address:"68:05:ca:c4:5e:8e"
Port:"Twisted Pair"
Speed:"Unknown!"
Availability:"ens9f1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500"
Default IP Gateway:"192.168.2.1"
DHCP Enabled:"Yes"
DHCP Lease Expires:"17:55:50"
DHCP Lease Obtained:"6月 5 15:16"
DHCP Server:"192.168.2.1"
Driver:"igb"
Driver Version:""
Duplex:"Full"
Interface:"ens9f1"
IP Address:"192.168.2.96"
IP Subnet:"255.255.255.0"
MAC Address:"68:05:ca:c4:5e:8f"
Port:"Twisted Pair"
Power Management:"Supports Wake-on: d"
Power Management:"Wake-on: d"
Speed:"1000Mb/s"
Availability:"ens9f2: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Interface:"ens9f2"
MAC Address:"68:05:ca:c4:5e:90"
Port:"Twisted Pair"
Speed:"Unknown!"
Availability:"ens9f3: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"igb"
Driver Version:""
Interface:"ens9f3"
MAC Address:"68:05:ca:c4:5e:91"
Port:"Twisted Pair"
Speed:"Unknown!"
- Interface virbr0
Auto-Negotiation:"Not Available"
Availability:"virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500"
Capabilities:"Not Available"
Caption:"Intel Corporation I350 Gigabit Network Connection (rev 01)"
DHCP Enabled:"Yes"
Driver:"bridge"
Driver Path:"/lib/modules/3.10.0-1160.el7.x86_64/kernel/net/bridge/bridge.ko.xz"
Driver Provider:""
Driver Version:""
Duplex:"Not Available"
Firmware Version:"N/A"
Interface:"virbr0"
IP Address:"192.168.122.1"
MAC Address:"52:54:00:8d:0e:d3"
Manufacturer:"Not Available"
Port:"Not Available"
Power Management:"Not Available"
Supported Link Modes:"Not Available"
Advertised link modes:"Not Available"
- Interface virbr0-nic
Supports auto-negotiation:"No"
Advertised auto-negotiation:"No"
Auto-negotiation:"off"
Availability:"virbr0-nic: flags=4098<BROADCAST,MULTICAST> mtu 1500"
DHCP Enabled:"Yes"
Driver:"tun"
Driver Path:"/lib/modules/3.10.0-1160.el7.x86_64/kernel/drivers/net/tun.ko.xz"
Driver Provider:"(C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>"
Driver Version:""
Duplex:"Full"
Firmware Version:""
Interface:"virbr0-nic"
Port:"Twisted Pair"
Speed:"10Mb/s"
Supported link modes:"Not reported, Supported pause frame use: No"
Advertised link modes:"Not reported, Advertised pause frame use: No"
- Operating System
Boot Device:"/dev/mapper/centos-root"
Last Reset:"up 13 min"
Locale:"zh_CN"
OS Manufacturer:"CentOS Linux release 7.9.2009 (Core)"
OS Name:"CentOS Linux release 7.9.2009 (Core)"
Page File:"Filename
/dev/dm-1"
Page File Space (Available):"Size
12505084"
Page File Space (Used):"Used
0"
Physical Memory (Available):"60645 MB"
Version:"3.10.0-1160.el7.x86_64 GNU/Linux"
Virtual Memory (Available):"12505084"
Virtual Memory (Total):"65402872"
- Processor
- "Intel(R) Xeon(R) Gold 5315Y CPU @ 3.20GHz"
Architecture:"x86_64"
Available:"Offline"
Byte Order:"Little Endian"
Cache Size:"12288 KB"
Caption:"Intel(R) Xeon(R) Gold 5315Y CPU @ 3.20GHz"
- Characteristics
64-bit capable
Enhanced Virtualization
Execute Protection
Hardware Thread
Multi-Core
Power/Performance Control
CPU Speed (Minimum):"799.804"
CPU Speed (Maximum):"3600 MHz"
Current Voltage:"1.6 V"
External Clock:"100 MHz"
Family:"Xeon"
- Flags
"ACPI (ACPI supported)"
"APIC (On-chip APIC hardware supported)"
"CLFSH (CLFLUSH instruction supported)"
"CMOV (Conditional move instruction supported)"
"CX8 (CMPXCHG8 instruction supported)"
"DE (Debugging extension)"
"DS (Debug store)"
"FPU (Floating-point unit on-chip)"
"FXSR (FXSAVE and FXSTOR instructions supported)"
"HTT (Multi-threading)"
"MCA (Machine check architecture)"
"MCE (Machine check exception)"
"MMX (MMX technology supported)"
"MSR (Model specific registers)"
"MTRR (Memory type range registers)"
"PAE (Physical address extension)"
"PAT (Page attribute table)"
"PBE (Pending break enabled)"
"PGE (Page global enable)"
"PSE-36 (36-bit page size extension)"
"PSE (Page size extension)"
"SEP (Fast system call)"
"SSE2 (Streaming SIMD extensions 2)"
"SSE (Streaming SIMD extensions)"
"SS (Self-snoop)"
"TM (Thermal monitor supported)"
"TSC (Time stamp counter)"
"VME (Virtual mode extension)"
ID:"A6 06 06 00 FF FB EB BF"
Level 1 Cache:"L1d cache: 48K
fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp lm constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx smx est tm2 ssse3 sdbg fma cx16 xtpr pdcm pcid dca sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm abm 3dnowprefetch epb cat_l3 invpcid_single intel_pt ssbd mba ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid fsgsbase tsc_adjust bmi1 hle avx2 smep bmi2 erms invpcid rtm cqm rdt_a avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 cqm_llc cqm_occup_llc cqm_mbm_total cqm_mbm_local dtherm ida arat pln pts hwp hwp_act_window hwp_epp hwp_pkg_req avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq md_clear pconfig spec_ctrl intel_stibp flush_l1d arch_capabilities"
Level 2 Cache:"L2 cache: 1280K"
Level 3 Cache:"L3 cache: 12288K
Load:"load average: 0.63, 0.33, 0.19"
Manufacturer:"Intel(R) Corporation"
Model:"Not Available"
Name:"Intel(R) Xeon(R) Gold 5315Y CPU @ 3.20GHz"
Number of Cores:"8"
Number of Cores - Enabled:"8"
Part Number:"Not Available"
Socket Designation:"CPU0 CPU1"
Status:"Populated, Enabled"
Version:"Intel(R) Xeon(R) Gold 5315Y CPU @ 3.20GHz"
Voltage:"1.6 V"
Virtualization:"Not Available"
- Storage
- "DERLAR SSD 128GB"
Caption:"/dev/sda"
Cylinders - Total:"Not Available"
Description:"Not Available"
Firmware:"Not Available"
Heads - Total:"Not Available"
Index:"Not Available"
Interface Type:"Not Available"
Name:"Not Available"
Partitions:"Not Available"
Sectors - Per Track:"Not Available"
Serial Number:"Not Available"
Size:"Not Available"
Size - Available:"Not Available"
SMART Attributes:"Not Available"
- SMART
001 Raw_Read_Error_Rate :100:"050"
005 Reallocated_Sector_Ct :100:"010"
009 Power_On_Hours :100:"000"
012 Power_Cycle_Count :100:"000"
161 Unknown_Attribute :100:"050"
162 Unknown_Attribute :100:"000"
163 Unknown_Attribute :100:"000"
164 Unknown_Attribute :100:"000"
166 Unknown_Attribute :100:"000"
167 Unknown_Attribute :100:"000"
168 Unknown_Attribute :100:"000"
169 Unknown_Attribute :100:"000"
171 Unknown_Attribute :100:"000"
172 Unknown_Attribute :100:"000"
174 Unknown_Attribute :100:"000"
175 Program_Fail_Count_Chip :100:"000"
181 Program_Fail_Cnt_Total :100:"000"
187 Reported_Uncorrect :100:"000"
194 Temperature_Celsius :100:"000"
195 Hardware_ECC_Recovered :100:"000"
196 Reallocated_Event_Count :100:"000"
199 UDMA_CRC_Error_Count :100:"000"
206 Unknown_SSD_Attribute :100:"000"
207 Unknown_SSD_Attribute :100:"000"
232 Available_Reservd_Space :100:"000"
241 Total_LBAs_Written :100:"000"
242 Total_LBAs_Read :100:"000"
249 Unknown_Attribute :100:"000"
250 Read_Error_Retry_Rate :100:"000"
- "OnlyDisk"
Caption:"/dev/sdb"
Hi kolink,
Thank you for your response.
We appreciate you sharing your concern with us. Please rest assured that we understand the importance of your situation and are fully committed to assisting you.
Please allow us some time to check this with the internal team, and we will get back to you as soon as we have an update.
If you have any additional information or questions, please feel free to share them with us. We're here to support you every step of the way.
Simon
Hello kolink,
Thank you for patiently waiting.
Upon investigating on this case, may I know if the link is up/down during the system restart?
It could be checked from the here: https://hsdes.intel.com/resource/14022654191.
If there is link up/down, meaning that the NC-SI port link status is reported correctly.
Sazzy_Intel
Thank you very much for your reply.
Unfortunately the link shows failure (https://hsdes.intel.com/resource/14022654191),
The server was connected to a network cable when it was restarted.
When the server runs the OS, this message is no longer reported.
Hi kolink,
Thank you for your reply.
Can you provide the screenshot of the website shows failure?
Sazzy_Intel
The page cannot be accessed is displayed.
I was so confused that I tried using chrome and edge, and it was the same phenomenon.
Hello Kolink,
Thank you for the screenshot. The link shared earlier is redirecting to : https://hsdes.intel.com/appstore/article/#/14022654191 from our end.
Could you try accessing : https://hsdes.intel.com/appstore/article/#/14022654191 directly and see if you are able to access the page?
Sachin KS
Still can't open the link inside.
Could you please send the main content to my email( Loomux@outlook.com )?
Looking forward to it.
Thank you very much.
Hello kolink,
Thank you for the update!
We are checking this and we will get back to you with an update at the earliest.
Sachin KS
Hi Kolink,
Please confirm if you have checked the link partner (switch port, other system) for link down during the restart?
If not, kindly check and share your observation.
Best Regards
Arun_Intel
Hi Kolink,
Best Regards
Arun_Intel
Hi Kolink,
Warm greetings and good day to you.
This is gentle follow up on this issue.
We would appreciate if you can let us know whether have you checked with the link partner (switch port, other system) for link down during the restart?
If yes, kindly share your observation.
Ragulan_Intel
Hi Kolink,
Greetings!
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
You can still re-open the case by logging into your web portal or replying to this email or talk to Intel Customer support and provide the case number.
Please note that if the case is re-opened more than 15 days after closure, a new case will be created with a reference to the original case.
You may receive an invitation to take a survey in a few days. We value your feedback and look forward to hearing about your support experience.
Ragulan_Intel
