Ethernet Products
5757 Discussions
Why is my network adapter disabled?
JPine5
I have a problem with the network adapter, repeatedly it is disabled or appears with limited access.
Nowadays I have devices with Windows 10 enterprise and the model adapter is Intel(R) Ethernet Connection I219-LM.
We have tried upgrading the driver but the issue still appear, also we have changing the speed and the duplex mode.
Somebody have had the same problem.?
AlHill
provide your w10 version number. Go to start, settings, system, about, and go to the bottom of the page.
Doc
JPine5
Hi, the version number is 1709 and the OS build is 16299.1087
Regards.
AlHill
1709 is no longer supported. Upgrade to 1809 here: https://www.microsoft.com/en-us/software-download/windows10
Doc
JPine5
which is not compatible?
AlHill
You need to be on a supported version of Windows 10. 1709 is not a supported version.
Doc
JPine5
Is that the reason why the adapter is disabled or is it placed in a limited access state?
I have several cases like this in my LAN.!
AlHill
You are on an unsupported version of windows 10. Why are you reluctant to upgrade and be current?
Doc
