Ethernet Products
4901 Discussions
Windows 7 x64 and 82577LM
First, sorry for my english, I'm French.
I still can't test with W7 x86 if the problem is similar but with the latest drivers here, I've got a lot of bad checksum. I use Wireshark.
My bandwidth isn't so bad but I've Ubuntu 10.10 x64 on the same laptop (it's a Dell E6410 and I've made a clean install of W7, without Dell's programs) and I don't have any errors using Wireshark and doing the same test. The bandwidth is also better under Ubuntu than Windows 7.
I love the Intel drivers on Windows with an integrated cable tester but it seems there is a problem with them, or maybe with Dell. I've made a test on a E6510 and the problem is the same.
Sorry if I haven't seen the solution here!
Thank you for your help.
Best regards!
Orchal
Mark_H_Intel
Thank you for your report. I would like to collect some additional information to help track down the issue you have reported.
Please confirm the driver and driver version for Windows 7 that you are using? Is your driver e1k62x64.sys? Is the version 11.8.75.0, dated 09/29/2010?
Are you seeing the errors on the 32-bit, 64-bit, or both versions of Windows 7?
Are you using all default settings for Windows TCP/IP and for Network Connection? If no, what changes have you made?
Are you seeing errors with IPv4, IPv6, or both?
Mark H
First thank you for your fast reply. I'm using the 11.8.75.0 dated 09/29/2010 drivers on Windows 7 x64. As I said, I can't test on a x86 version of Windows 7 because I don't have any laptop or desktop with a 82577LM network adapter under this version.
I'm using all defaut settings for Windows TCP/IP and Network Connection. I've tried on my laptop, on which I maybe made changes, but I've tried on a fresh installed Dell E6510 Laptop and the problem is the same.
I can't try with IPv6 so i'm seeing errors with IPv4.
I've tried earlier drivers and this doesn't solve my problem.
Thank you a lot !
Orchal
Mark_H_Intel
Are the checksum errors you are seeing in Wireshark are IPv4 checksums? TCP checksums? UDP Checksums? All checksums?
Try disabling TCP/IP offloads in the advanced settings to see if any of the settings change what you see with Wireshark.
Mark H
This seems to solve my problem. I don't see errors anymore and the bandwidth is what it should be !
Thanks a lot !
Best regards.
Mark_H_Intel
Which offloads did you disable to resolve the issue?
Mark_H_Intel
Disabling TCP/IP offloads will put more load on your CPU. I did not see what Wireshark checksum errors you were seeing, but I am guessing these were probably not real errors. The thread at http://ask.wireshark.org/questions/634/acc-to-wireshark-999-of-my-outgoing-packets-have-a-bad-checksum http://ask.wireshark.org/questions/634/acc-to-wireshark-999-of-my-outgoing-packets-have-a-bad-checksum has good information.
Nevertheless, enabling TCP/IP offloads gave you reduced performance in comparison to Ubuntu. I suspect that the performance issues might be able to be resolved with some network tuning in Windows. I found a number of possible tweaks listed at http://www.speedguide.net/articles/windows-7-vista-2008-tweaks-2574 http://www.speedguide.net/articles/windows-7-vista-2008-tweaks-2574. I have not experimented with these myself, but some of these tweaks might help you.
I hope this helps.
Mark H
