Ethernet Products
5736 Discussions
Wired ethernet failed on Ubuntu 12.04 LTS with Intel 82579LM / Intel 82574L
TLin36
Fresh install of Ubuntu 12.04 LTS desktop on my workstation.
I have
  • Eth0 Intel 82579LM Gigabit Network Connection
  • Eth1 Intel 82574L Gigabit Network Connection
Installed the latest (3.3.3) drivers https://downloadcenter.intel.com/download/15817/Network-Adapter-Driver-for-PCI-E-Gigabit-Network-Connections-under-Linux- Download Network Adapter Driver for PCI-E* Gigabit Network Connections under Linux* by unpacking, make, sudo make install, modprobe with reboot.
Wired internet doesn't seem to work.
Cable is showed as visual plugged but is displayed disconnected (keeps reconnecting)
Installing version 2.5.4 with same results
/etc/network/interfaces:
auto lo
iface lo inet loopback
Thanks in advance!!
st4
New Contributor III
Hi tommyboy14,
Please check on the https://downloadmirror.intel.com/15817/eng/README https://downloadmirror.intel.com/15817/eng/README regarding the
Building and Installation note.
NOTE:
For certain distributions like (but not limited to) RedHat Enterprise
Linux 7 and Ubuntu, once the driver is installed the initrd/initramfs
file may need to be updated to prevent the OS loading old versions
of the e1000e driver. The dracut utility may be used on RedHat
distributions:
# dracut --force
For Ubuntu:
# update-initramfs -u
rgds,
wb
TLin36
Hello WB,
Sorry, I forgot to mention. I already did that, no effect.
st4
New Contributor III
Hi Tommyboy14,
Please check with the board vendor for customized driver for this onboard NIC on the system to see if this will make any difference.
thanks,
wb
Was this issue ever resolved? I am having the same issue but with a different board.
