Is there a nightly build or something I can try? I see Ubuntu 22.04 LTS support, which I can try. Not sure if the difference in 5.15 to 5.19 kernel would impact this.
~/ixgbe-5.18.6/src$ make install
*** The target kernel has CONFIG_MODULE_SIG_ALL enabled, but
*** the signing key cannot be found. Module signing has been
*** disabled for this build.
make[1]: Entering directory '/usr/src/linux-headers-5.19.0-29-generic'
warning: the compiler differs from the one used to build the kernel
The kernel was built by: x86_64-linux-gnu-gcc-12 (Ubuntu 12.2.0-3ubuntu1) 12.2.0
You are using: gcc (Ubuntu 12.2.0-3ubuntu1) 12.2.0
CC [M] /home/jm/ixgbe-5.18.6/src/ixgbe_main.o
/home/jm/ixgbe-5.18.6/src/ixgbe_main.c: In function ‘ixgbe_configure_dcb’:
/home/jm/ixgbe-5.18.6/src/ixgbe_main.c:5830:25: error: implicit declaration of function ‘netif_set_gso_max_size’; did you mean ‘netif_set_tso_max_size’? [-Werror=implicit-function-declaration]
5830 | netif_set_gso_max_size(netdev, 65536);
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:257: /home/jm/ixgbe-5.18.6/src/ixgbe_main.o] Error 1
make[1]: *** [Makefile:1850: /home/jm/ixgbe-5.18.6/src] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.19.0-29-generic'
make: *** [Makefile:99: default] Error 2
- Tags:
- Ubuntu 22.10
completes just fine on Ubuntu 22.04 LTS
Hello jmhands,
For us to further check and investigate the issue, please provide the following details.
1. Please send photos on the unit on both sides focusing on the markings for us to validate if the unit is an OEM unit or not.
2. What is the brand and model of your board or system?
Just for note:
For Ubuntu supported version please refer to this link. Only Ubuntu 18.04 LTS and Ubuntu 20.04 LTS fully supported.
Also, please note the kernel supported for the ixgbe driver 5.18.6 on Ubuntu 22.04 is kernel release 5.15.
For Ubuntu 20.10 the kernel release 5.19 which isn't supported.
If you have questions, please let us know. In case we do not hear from you, we will make a follow up on Feb 15th 2023. Thank you.
Irwan_Intel
Intel® Customer Support
Hello jmhands,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know.
In case we do not hear from you, I will make a follow up on February 17th 2023 . Thank you.
Irwan_Intel
Hi jmhands,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Irwan_Intel
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
