Ethernet Products
5660 Discusiones
X540-T1 driver performance issues.
Emjayen
Principiante
1.736 Vistas
Under moderate rx packet rates (~10Mpps) there's significant performance issues with the driver's WPP trace logging, presumably on the data-path for some reason.
I'm quite confident it's indeed the driver actually invoking this, given other cards (e.g, Mellanox) at far higher packet rates do not exhibit this behavior.
Attached is the SUS output which appears to be standard here.
Matt.
0 kudos
6 Respuestas
Faez_Intel
Empleados
1.634 Vistas
Hi Matt,
Good day and thanks for posting in the Intel Community Support.
May I know was there any changes made to the NIC prior to this performance issues?
Please ensure if you have set the autonegotiation on the network adapter, the switch should be in autonegotiation mode. Do the same if you set the network adapter to 1000 mbps, the switch should be in 1000 mbps.
Looking forward to hear from you.
Faez_Intel
Emjayen
Principiante
1.618 Vistas
Hi Faez,
This is an issue related to driver implementation. It'll need to be looked into by an engineer/developer of the driver software.
IntelSupport
Administrador
1.602 Vistas
Hello Emjayen ,
Thank you for the response.
We are currently in the process of reviewing the information you have provided, and we will promptly update you once we have the necessary details. We kindly request your cooperation during this time.
Sreelakshmi B
Faez_Intel
Empleados
1.488 Vistas
Hello Emjayen,
Good day.
May I know if you are using the latest drivers for the NIC? Also, may I know if you are using the Intel generic drivers or if this is from an OEM NIC?
Faez_Intel
Emjayen
Principiante
1.484 Vistas
Hi Faez,
Yes, these are the latest drivers according to the ISM software (and a manual check). They are generic drivers; this is an add-on card.
Emjayen
Principiante
1.198 Vistas
Any follow-up to this issue?
Responder
