Ethernet Products
4902 Discussions
X710-DA2 NVM Update not available
MMike7
Got Supoermicro server from supplier with X710-DA2 Card
I'm install FreeBSD 11, update to stable and have next messages:
ixl0: mem 0xf8000000-0xf8ffffff,0xf9008000-0xf900ffff irq 32 at device 0.0 on pci3
ixl0: Using MSIX interrupts with 9 vectors
ixl0: fw 4.33.31377 api 1.2 nvm 4.41 etid 80001866 oem 16.4096.10
ixl0: The driver for the device detected an older version of the NVM image than expected.
So I try update NVM under FreeBSD:
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.26.17.11
Copyright (C) 2013 - 2016 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [Segmentation fault (core dumped)
Then I try update NVM under Ubuntu, download and install driver
# ethtool -i enp2s0f0
driver: i40e
version: 1.5.25
firmware-version: 4.41 0x80001866 16.5.10
expansion-rom-version:
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
# lspci |grep 710
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
02:00.1 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
and got
XL710/Linux_x64# ./nvmupdate64e
Inventory in progress. Please wait [|.........]
Num Description Device-Id B:D Adapter Status
01) Intel(R) Ethernet Converged Network Ad 8086-1572 02:00 Update not available
02) Intel(R) I350 Gigabit Network Connecti 8086-1521 05:00 Update not available
Tool execution completed with the following status: Device not found
Press any key to exit.
lspci -v with serial number attached
MMike7
Also when I try update from uefi, process stop at
I wait 10 minutes, reset server and retry 5 times. No changes.
Hi Umike,
Thank you for the post. Is there any way you can provide me the physical serial number on the NIC? I need to identify the PBA number of the NIC, the complete serial # can be found on the adapter itself (NOT ON THE BOX), with the format of 15 alphanumeric (space) 6 alphanumeric (space) 6 alphanumeric - 3 digits.
thanks,
wb
MMike7
Hi
I discovered that it's Dell branded NIC and start using Dell Firmware update tool.
It's updated to 16.5.20 from Dell, next 17.0.0 and 17.0.5 got
Running validation...
This Update Package is not compatible with your system configuration.
and still have
Please update the NVM image.
in BSD.
Card have next label:
3CFDFE0AA0E0
032 2315AD
H54188 - 005
no more labels with long text like serials
Can I reflash this NIC to native Intel Retail? As I see nvmupdate have "force" option.
MMike7
or maybe it's not Dell, I don't know. Here photos:
https://www.dropbox.com/s/nuhmhjzo77bre76/DSC_0651.JPG?dl=0 Dropbox - DSC_0651.JPG
https://www.dropbox.com/s/lnye8ptx7ovhv2k/DSC_0654.JPG?dl=0 Dropbox - DSC_0654.JPG
Nvmupdate -i show this inventory
I'm attach lspci -v file
and I have no more information about it
[02:00:00]: Intel(R) Ethernet Converged Network Adapter X710
Vendor : 8086
Device : 1572
Subvendor : 8086
Subdevice : 6
Revision : 1
LAN MAC : 3CFDFE0AA0E0
Alt MAC : 000000000000
SAN MAC : 3CFDFE0AA0E1
ETrackId : 80001866
Flash update : No update
VPD size : 261
EEPROM update : No update
checksum : valid
OROM update : No update
CIVD : 16.5.20
PXE : 1.0.10, checksum Not Relevant
ISCSI : 3.0.44, checksum Not Relevant
ISCSI_SETUP : 3.0.44, checksum Not Relevant
EFI_X64 : 1.1.33, checksum None
CLP_LOADER : 3.0.30, checksum Valid
IMAGE_SHARED_40G : 1.0.7, checksum Not Relevant
[02:00:01]: Intel(R) Ethernet Converged Network Adapter X710
Vendor : 8086
Device : 1572
Subvendor : 8086
Subdevice : 0
Revision : 1
LAN MAC : 3CFDFE0AA0E2
SAN MAC : 3CFDFE0AA0E3
ETrackId : 80001866
VPD size : 261
checksum : valid
CIVD : 16.5.20
Hi Umike,
This is not Intel version network adapter, as H54188 is not the PBA number for X710 of Intel retail adapter, pls refer to URL below
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005612.html
Have you tried contacting Dell* for the firmware reflash or roll back to their firmware ?
rgds,
wb
MMike7
As I write, update to 16.5.20 from Dell, then try to update 17.0.0 and 17.0.5 from Dell, but
I'm try contact Dell, but still no answer
Can I change NVM/flash to Intel retail?
maybe I can use some trick with nvmupdate as described here in answer?
We need start production server tomorrow with or without Intel card . Already 3 days we have no real support, can You do real help?
Hi Umike,
I am sorry you need to contact Dell* for the firmware still as it is recommended to use Dell's firmware.
rgds,
wb
Hi Umike,
Just to double check also if you have tried the following: Upgrade first via previous NVMUpdate version which is downloadable at
https://downloadcenter.intel.com/download/25222/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-X710-Series
Then proceed to upgrade to the newer NVMupdate version:
https://downloadcenter.intel.com/download/24769/NVM-Update-Utility-for-Intel-Ethernet-Converged-Network-Adapter-XL710-X710-Series
Hope this helps.
rgds,
wb
AElsu
I want to note, that nvmupdate64e gets segmentation fault under FreeBSD 12 too.
# ktrace ./nvmupdate64e
# kdump | less
12102 nvmupdate64e CALL open(0x7304fc,0x2)
12102 nvmupdate64e NAMI "/dev/mem"
12102 nvmupdate64e RET open 4
12102 nvmupdate64e CALL ioctl(0x5,PCIOCREAD,0x7fffffffd960)
12102 nvmupdate64e RET ioctl 0
12102 nvmupdate64e CALL __sysctl(0x7fffffffd968,0x2,0x7fffffffd964,0x7fffffffd970,0,0)
12102 nvmupdate64e SCTL "p1003_1b.pagesize"
12102 nvmupdate64e RET __sysctl 0
12102 nvmupdate64e CALL mmap(0,0x20000,0x3,0,0x4,0xdfa20000)
12102 nvmupdate64e RET mmap -1 errno 13 Permission denied
12102 nvmupdate64e CALL __sysctl(0x7fffffffd978,0x2,0x7fffffffd974,0x7fffffffd980,0,0)
12102 nvmupdate64e CALL mmap(0,0x4000,0x3,0,0x4,0xdfa44000)
12102 nvmupdate64e PSIG SIGSEGV SIG_DFL code=SEGV_MAPERR
12102 nvmupdate64e NAMI "nvmupdate64e.core"
Hi Umike,
Thank you for the update. Have you tried contacting Dell* for the firmware?
wb
AElsu
I am not Umike, I was looking for the solution for the same problem and found this theme.
I added some technical details that I gathered from the system where this core dump is quite reproducible.
Hi Butcher,
Thank you for the info. What is the serial number of your X710? The complete serial # can be found on the adapter itself (NOT ON THE BOX), with the format of 15 alphanumeric (space) 6 alphanumeric (space) 6 alphanumeric - 3 digits.
rgds,
wb
Hi Butcher,
Please feel free to provide the info.
rgds,
wb
