Updating an Intel X710-DA2 to the latest version (9.30) does not work and fails with the following output:
I also tried it with Windows but that also failed with the same error. Rerunning an older fw package (e.g. v9.10 - note v9.20 also fails) works.
We already discussed it here => X710-DA2 Update not working - Unsupported OROM Combo Image - Intel Community
A user (with the same problem) over there found a "workaround" for updating the firmware but with the downside of losing some functions.
Also as written there. Something seems wrong with the BootIMG.FLB / OROM Image. On the same system, I can rerun the v9.10 update package without a problem, so it somehow must be a problem with the newer firmware package.
The BootIMG.FLB file in the old update package v9.10 is also substantially larger 1 683 014 bytes vs 1 379 463 bytes. I guess something is missing there. Quickly analyzing those files in a text editor also shows something is clearly missing in the new version.
Also for comparison:
v9.01 BootIMG.FLB = 1 683 014 bytes - update works
v9.10 BootIMG.FLB = 1 683 014 bytes - update works
v9.20 BootIMG.FLB = 1 310 096 bytes - update does not work
v9.30 BootIMG.FLB = 1 379 463 bytes - update does not work
Thanks!
Alex
Greeting Alexander,
Sorry to hear that, we would like to suggest you go ahead and post your questions in Intel Embedded Community, follow the link below:
Embedded Connectivity - Intel Community
You need to click on Embedded group and post this question.
Hence, I will proceed to close this thread.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Thank You & Regards
Yogaeasvaran
Intel® Customer Support
Oh lol, didn't notice that I had created the issue on the same page again. **bleep** it... Sorry. I will open a new one on the embedded connectivity subforum.
