Ethernet Products
Intel® Ethernet products and technologies
4255 Discussions
X710/XL710 Quad port 10g base-t NMV and drivers
jsavlen
X710 Quad port 10g base-t
Can someone point me to a list or matrix of intel recommended NVMe update and driver version
based on operating system?
i.e. RHEL7, 8, 9
John
Mike_Intel
Hello jsavlen,
For us to further check the issue, please provide the following details.
  1. Are you using a PCIe X710 or onboard/embedded network card?
  2. What is the brand and model of your board/system?
  3. Are you having issues with your X710 network controller?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
jsavlen
Hi Michael,
The card is an Intel X710 PCIe add-on card
Its installed in an Oracle X6-2 server w/two Intel Xeon Processor E5 V4 Series
I upgraded the NVM firmware to version 8.7.0 without issue.
I was able to upgrade i40e to 2.17.15 when the system was running Oracle Linux 7.9
i40e upgrade, running Oracle Linux 8.3 and 8.5, build failed error indicated missing or incompatible kernel-devel packages
Installed new kernel-devel packages.
I tried i40e versions 2.17.15 to 2.20.12 with the same result
I hope this provides a clearer picture.
John
Mike_Intel
Hello jsavlen,
I hope you're having a wonderful day. I am just sending a soft follow up on the information that we requested for us to further assist you. We will wait for your reply.
Michael L.
Mike_Intel
Hello jsavlen,
Thank you for the quick reply. Let me gather more details for us to understand the issue better.
  1. Can you send photos of the card on both sides for us to validate and check if the card is not an OEM unit?
  2. Kindly provide the link of the NVM file that you use to update the firmware.
  3. Kindly provide the link of the driver that you used.
  4. Please share the screenshot of the issue.
Michael L.
Mike_Intel
Hello jsavlen,
Michael L.
Mike_Intel
Hello jsavlen,
I am sending another follow up on the information that we requested.
If you need further assistance, please post a new question.
Thank you and stay safe.
Michael L.
jsavlen
Hi Michael,
Apologies for the delay.
Its a PCIe X710 Quad port base-T
The requested pics are attached
NMV update URL https://www.intel.com/content/www/us/en/download/18190/732157/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapter-700-series.html
Driver URL https://www.intel.com/content/www/us/en/download/18026/709707/intel-network-adapter-driver-for-pcie-40-gigabit-ethernet-network-connections-under-linux.html
System is Oracle X6-2 server w/two Intel Xeon Processor E5 V4 Series
Oracle Linux 8.3 and 8.5 make failed error indicates missing or incompatible kernel-devel packages
John
