Ethernet Products
5821 Discussions
X722 drivers for Linux Kernel 2.6.x
VS77
I have a need for X722 drivers for an older linux kernel.  Attempting to build a rpm from the e1000e-3.8.7 tarball (claims to work all the way back to linux 2.4) results in errors for missing include files that don't seem to be on 2.6
Setup:  Legacy software running RHEL5.2 on an upgraded motherboard with onboard X722 ethernet ports.  The kernel version cannot be changed, but hardware drivers can be added or updated.
vij1
Hello VS77,
Greetings for the day!
Kindly confirm the driver version currently using for X722 Intel® Ethernet Controllers.
Vijay.
vij1
Hello VS77,
We are currently awaiting your response regarding the case. If you have any queries or require further assistance, please feel free to respond on the community post. We are more than happy to assist you.
Vijay N.
VS77
output from "lspci -v"
Ethernet controller: Intel Corporation Unknown device 37d2 (rev 09)
Subsystem: Super Micro Computer Inc Unknown device 37d2
Flags: fast devsel
Memory at fc000000 (64-bit, prefetchable) [size=16M]
Memory at fe100000 (64-bit, prefetchable) [size=32K]
Capabilities: [40] Power Management version 3
Capabilities: [50] Message Signalled Interrupts: 64bit+ Queue=0/0 Enable-
Capabilities: [70] MSI-X: Enable- Mask- TabSize=129
Capabilities: [a0] Express Endpoint IRQ 0
The ports show up in "lspci", but not in "ip a" or "ifconfig"
a "find" in /sys/bus/pci/drivers/ for the pci addresses returns nothing.
vij1
Hello VS77,
We are checking on this issue and will get back as soon as possible.
Vijay N.
VS77
I found that the e1000e driver does exist in the kernel, and loaded it.
after
echo 8086 37d2 > /sys/bus/pci/drivers/e1000e/new_id
and
echo 0000:00:08.0 > /sys/bus/pci/drivers/e1000e/bind
I get
bash: echo: write error: Input/output error
Does the x722 only work with i40e?
I'm currently looking into backporting i40e, but there's not much support left for Linux 2.6.18-419 and backporting is new to me.
vij1
Hello VS77,
Have you already tried the latest driver from our site below?
Intel® Network Adapter Driver for PCIe* 40 Gigabit Ethernet Network Connections under Linux*
https://www.intel.com/content/www/us/en/download/18026/intel-network-adapter-driver-for-pcie-40-gigabit-ethernet-network-connections-under-linux.html
 We'd like to inform you that that RHEL5.2 is not listed as validated Operating System on X722. You may consider testing the driver on supported OS.
Supported Operating Systems for Intel® Ethernet Controllers (LOM)
https://www.intel.com/content/www/us/en/support/articles/000055236/ethernet-products/gigabit-ethernet-controllers-up-to-2-5gbe.html
Vijay N.
VS77
Unfortunately I do not get to choose the Operating System.
i40e won't build that easily because it needs 2.6.32 or later while I'm on 2.6.18
vij1
Hello Vince,
Greetings!
Thank you for your response. As per your confirmation that you require the latest version of 2.6.32 to build i40e, we recommend contacting Linux support for further assistance.
Vijay N.
vij1
Hello Vince,
We are following up to find out if you were able to find the information we provided. Please reply to confirm, so we can continue helping on a resolution. Looking forward to receiving your reply.
Vijay N.
vij1
Hello Vince,
We have not received a reply from you , and as such, we will be closing your case.
If you want to continue support, please reply to this email and we will reopen your case or create a new one so that we can continue to support you.
Vijay N.
